A/D conversion problem in 18F2520, 2523, 2550 etc.
Results 1 to 10 of 10
    Also in the datasheet for a 2550/4550...
    The internal AD/RC oscillator is not a good idea on PIC chips if you want extreme accuracy.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2395&stc=1&d=120499947 4" />
    Try a different AD clock setting ...
    ADCON2=%10100110  ; 64 TOSC, 8-TAD sample
    Also, since you're not using ADCIN, the ADC_ DEFINE's don't do anything.
    Default Improving ADC repeatability
    High ADC accuracy and repeatability takes dedication at the PCB layout stage. There must be analog ground right beside the analog input and overall copper pour ground planes. Keeping all analog circuitry within its own fenced are of copper usually helps quite a bit.
    Another good technique (thanks Melanie) is to take 16 readings, sort them, throw out the top 4 and the bottom 4 then average the eight values that are left. That technique eliminates the outliers and tames the last one or two counts.
    I have also found several ADC ticks of noise/variability can be eliminated by locking the sampling point to the mains. I bring low voltage AC to an optocoupler and use that to trigger the ADC conversion. Varying the delay after the mains zero crossing will usually show a sweet spot where the fluorescent lights and other electrical loads are fairly quiet. I NEVER attempt 16 bit ADC without mains locking.
    Sloppy techniques that are invisible with 8 bit conversion start showing up with 10 bits and can make the transition to 12 or 16 bit ADC a worthless expedition.
    HTH
    BrianT
    Quote Originally Posted by BrianT View Post
    Might help.
    I think she's said it several times, here's one of them.
    At least the sorting part.
    http://www.picbasic.co.uk/forum/showthread.php?t=134 <-- 134
    selimkara's Avatar
    selimkara Guest
    Many Thanks to everybody for their supports,
    Yes Alain, it may be impedance problem or Offset voltage drift in Op-Amps but it is not.
    As I said before, I tried many techniques and schemes, I used OP27 (very low offset) with symmetrical power supply and I always precisely check that kind of voltage drifts. Then I used MAX6241 (4096mV ref with a single supply). Sometimes I used a series resistor(1-4,7k) in analog inputs and/or/not capacitors (100-470 nF) between these pins and GND.
    May I ask you, did you ever precisely measure the voltages with a 1 mV (or lower) resolution voltmeter? If everything is okay may I see the summarized ADC section of your
    code (if it is in PBP)? Because I'll be insane soon.
    Thanks Darrell Taylor, I know, this code was one of the test code combinations.
    I read the manual's A/D section and desperately tried many clock setting parameters and
    also ADCIN command. These definition lines should be forgotten to be deleted.
    Staistical sort method is the last way, I used this technique only on the Maxim's high speed
    (100-200 kHz) 12-16 bits A/D converters. There was no need to use in 18F252.
    There must be a structural difference between 18F252 and 2520 to affect their using technique and resulting difficulties.
    BrianT, you are right, analog ground distribution is very important to prevent the voltage drops. I use protoboard for now but 18F252 was direct working in every condition. I don't understand this.
    Namely, I compare everything with 18F252 comfort and then getting angry.
    Can anybody write me a simple summarized code including definitions, settings and ADCIN usage. (I don't need high speed conversions. I want slow but stable and true results )
    (for 2520,4520, 2550 or 4550, all they have same A/D structure).
    And talk about differences between 18F252 or F452 and other new versions of these chips?
    Then, once again, I will try it on a PCB.
    Thank you
    Selim
    Lightbulb
    Hi, Selim
    First, I'd like to raise the problem data ...
    - Your scale is 1 - 4.096v with 10 bits resolution.
    - You want to read 10-20 mV
    That means you read with 4 mV per Bit ...
    The ADC count is always +/- 1 LSB ( rollover error ) ...
    So, your result is 1 to 5 +/- 1 ... I do not think you want to seriously regulate something with a +/ 20% input data error...
    Now, generally speaking, I always use a mean value - Nb of samples are a function of the measuring allowed time - and, to get rid of the rollover ... I then swap the LSB ...
    Moreover, when tracking the mV ... Ground Guard rings around the PIC inputs are to be used ( remember the inputs are "not so far" from the Xtal ... ).
    You'll notice the input leakage current has been reduced from +/- 500 nA ( '252) to +/- 100 nA ('2520) ... which means a much greater noise sensitivy ...
    I'd lead you to use a ground plane on the component's side, ADC section ...
    It would be interesting to know exactly what you want to do ... and how you do it ( input data range, sensors used, ...).
    I do not want to be rude ... but tracking 0 -20 mV with a 4v reference is a nonsense without "superior" PCB design skills ... as BrianT told.
    " May I ask you, did you ever precisely measure the voltages with a 1 mV (or lower) resolution voltmeter? "
    My multimeter is a 4.5 Digits ... so, 1 mV resolution.
    I really do not think the solution is in the code lines ...
    selimkara's Avatar
    selimkara Guest
    Thanks Alain,
    You analyzed all situations. Thank you. Let me try to explain all story.
    I'm a physics researcher at University. I study on polymer physics. I also graduated from Electronics technical high school, from now on, electronics is a hobby for me. I'm trying to make some controller devices to use in our polymer lab. We have a special hand made oven to anneal some polymer thin films at some constant temperatures (0-500 C). I transformed its "antique" (from 1990's) controller to a modern pic circuit. An E-Type (chromel-constantan) thermocouple is embedded in the oven, thermocouple temperature-voltage conversion table is loaded in the pic18F252. Approx. 60 uV/C x 100 times with OP27 opamps = 6 mV/C *500 =3500 mV max. Voltage reference is 2048 mV, so 1 step=2 mv. Resolution is approx. 2/6=0.3 C/step. At 500 C, Tcouple voltage is about 3700 mV. Namely, I can't reach the temps. above 2048 mV(approx.280 C) and my resolution is 0,3. If my ref. voltage was 4096 mV (with a 12-bit ADC), my resolution would be 1/6=0.16 C/step and also one can measure beyond 500 C.
    İncreasing the resolution is important for fast detecting of changes in temp. to keep the desired oven temperature.( I have written a "smart" code to fix it.). Data appears on the 6x led-displays and also transferred to a PC via RS232. It has many more features (clock, timer, alarm, statistics, scrolling menus, user programmable tcouple tables...30kB of 32kB is Full). I've attached the photos. I did specially not designed it with LCD screen and USB communication. My aim was produce a cheap, easy-to-make device for distrubute it other experimental workers. I successfully designed similar circuits with Maxim's 12-16 bit ADCs. But they are expensive and hard to be made.
    PIC18F2523 is a 12-bit pic. It's ADC module is same with 18F2520 or other new USB pics (18F2550, 4550..). First, as a beginning, I replaced the 18F252 with 18F2520 and changed the ADC code, but there's always a non-linear difference (10-20 mV at best condition), then I tried other new pics on a protoboard with many additions (filters etc.) and many different combinations in AD registers' parameters in the code, did not work.
    Anyway, I think I'll give up.
    I hope you understand my English. Thanks everybody.
    Selim
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. A/D conversion problem with 18F2455
    By abdy37 in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 15:53
  3. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 00:03
  4. A/D conversion problem with pic16F88
    By Tapio Linkosalo in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 12:42
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
