LCD dsiplay driving me up the wall!
Results 1 to 8 of 8
Threaded View
  1. #6
    Hello agross,
    Install some code to flash an LED just so you know the PIC is working, set your contrast so the squares are barely visable, usually I simply ground that pin, and mine work. Check your breadboards connections, especially the Osc connections.
    try:
    FLAGS = 0              ' Forces LCD to initialize
    pause 500              ' Allows the time
    lcdout $FE,1           ' Clears LCD
    lcdout $FE,2, "hello"  ' Returns to beginning of line 1 and writes "string"
    Check this link too . . .http://www.geocities.com/dinceraydin/lcd/commands.htm notice . . link has popup ads, not my link though . . .
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
