LCD dsiplay driving me up the wall!
Results 1 to 8 of 8
    agross, What actual display are you using? How do you have the contrast pin wired?
    Mar 2008
    I am using a powertip PC1602c LCD, I have the contrast set correctly because I can see the solid squares when I power the PIC and LCD panel up. The contrast pin is set by throing a pot on the bread board and then adjusting the wiper.
    Hello agross,
    Install some code to flash an LED just so you know the PIC is working, set your contrast so the squares are barely visable, usually I simply ground that pin, and mine work. Check your breadboards connections, especially the Osc connections.
    try:
    FLAGS = 0              ' Forces LCD to initialize
    pause 500              ' Allows the time
    lcdout $FE,1           ' Clears LCD
    lcdout $FE,2, "hello"  ' Returns to beginning of line 1 and writes "string"
    Check this link too . . .http://www.geocities.com/dinceraydin/lcd/commands.htm notice . . link has popup ads, not my link though . . .
    Lightbulb
    Hi, Agross
    Did you see this Thread ???
    http://www.picbasic.co.uk/forum/showthread.php?t=7871
    Mar 2006
    Hyderabad (India)
    While experts are already on job to help you on software front, I would suggest that you may put a schematic of what actually wired., in third dimension, irrespective of what your software speaks.
    this will really help the experts to confirm your wiring with ref. to software, here again, we don't expect a schematic published by some one, as it won't help checking the actual wiring done by you.
    Sarma
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
