Lookup Table
Results 1 to 7 of 7
Thread: Lookup Table
    Feb 2003
    Salt Lake City, Utah USA
    also find this excellent thread started by Melanie
    "Making Program Code Space your playground"
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Hi yasser,
    What precisely are you trying to do? PBP does not use RAM to create lookup tables except for the index & result variables.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Unhappy Peek, Poke, DB, ASM ...?
    Hi and thanks for your replies. I visited above links. I want to save data on program memory space and send them to LEDs byte by bytes. This is a part of my program:
    Send:
    StrAddr = $370
    for j = 0 to 2
    CharAddr = StrAddr + (80*j)
    for k = 0 to 79
    PeekCode CharAddr+k, x
    GOSUB DISPLAY
    next k
    next j
    Send_Back:
    StrAddr = $460
    for j = 2 to 0 step -1
    for k = 79 to 0 STEP -1
    GOSUB DISPLAY
    next k
    next j
    ' Introduction of Image *
    @ org 370h
    Pokecode $00,$00,$00,$00,$01,$01,$01,$03,$00,$00,$00,$00,$0 1,$01,$01,$03,$00,$00,$00,$00,$01,$01,$01,$03,$00, $00,$00,$00,$01,$01,$01,$03,$00,$00,$00,$00,$01,$0 1,$01,$03,$00,$00,$00,$00,$01,$01,$01,$03,$00,$00, $00,$00,$01,$01,$01,$03,$00,$00,$00,$00,$01,$01,$0 1,$03,$00,$00,$00,$00,$01,$01,$01,$03,$00,$00,$00, $00,$01,$01,$01,$03
    It doesn't work. Why?
    Can you tell me about DB usage? How can I use it? I used ASM code (as I said above). Why didn't it work correct?
    Thanks alot
    Default Thanks
    Thanks all.
  1. Lookup table syntax.....
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 19th May 2009, 04:45
  2. Lookup table or Math?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2008, 17:55
  3. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 17:56
  4. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 18:27
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
