Can't Blink 2 LEDs
Results 1 to 3 of 3
    Oct 2007
    Default Can't Blink 2 LEDs
    I am trying to blink 2 LEDS, like the railroad cross signal, but can't get it to work on a 12f629. I need to use the codes defined at below, which will make reassigning variables for other purposes easy. When I run this, only the "LEDBottom" blinks, which is that last one that the code executes. LEDTop stays on permanently. Can someone help?
    Here's what I have:
    'set input/output pins
    TRISIO = %111100 '1=input, 0=output
    'define variables
    LEDTop var GPIO.0
    LEDBottom var GPIO.1
    TurnOn var byte
    TurnOff var byte
    'set variables
    turnon = %0
    turnoff = %1
    'start of program
    LEDtop = turnoff
    Ledbottom = turnoff
    InputLoop:
    ledtop = turnon
    ledbottom = turnoff
    ledtop = turnoff
    ledbottom = turnon
    goto inputloop
    P.S. I don't want to use this:
    InputLoop:
    GPIO=%000001
    GPIO=%000010
    GOTO InputLoop
    May be just
    CMCON = 7
    Missing ...
    Oct 2007
    Talking It works...
    Thanks Acetronics!!!
  1. Code to control 4 LEDs and 2 servos
    Last Post: - 26th November 2008, 14:33
  2. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  3. Microcontroller with 2 way paging application problem
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
