Timer1 Problem
Results 1 to 6 of 6
Thread: Timer1 Problem
    Mar 2006
    Default Timer1 Problem
    I try to measure time elapsed between two events using Timer1 : (when variable Estatus remains =1) I use Pic 16F677
    I understand that overflow time of counter TM1 using 4 Mhz and Prescalers of 1, 2, 4, 8 should be 65, 131,262 and 524 msec but I always get a tick time of 76 msec in spite of using diferent prescalers through T1COM.4 and T1COM.5 settings
    Can someone suggest any hint to explain and avoid it?
    -Francesc
    Here is my code:
    DEFINE LCD_DREG PORTC 'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT 4 'Define first pin of portc connected to LCD DC4
    DEFINE LCD_RSREG PORTC 'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 3 'Define Portc pin used for RS connection
    DEFINE LCD_EREG PORTC 'Define PIC prot used for E line of LCD
    DEFINE LCD_EBIT 2 'Define PortC pin used for E connection
    DEFINE LCD_BITS 4 'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2 'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000 'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50 'Define delay time between data sent.
    @ DEVICE pic16F677, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16F677, WDT_ON
    @ DEVICE pic16F677, BOD_ON
    @ DEVICE pic16F677, PROTECT_OFF
    @ DEVICE pic16F677, PWRT_ON
    @ DEVICE pic16F677, MCLR_OFF
    TRISA=%11111111 ' A Register as input
    TRISB=%11111111 ' B Register as input
    TRISC=%00000000 ' C Register as output
    CM1CON0=0 ' Comparator disabled
    CM2CON0=0 ' Comparator disabled
    ANSEL=%00001111 ' analogic=1 digital=0
    ANSELH=%1110100 ' analogic=1 digital=0
    T1CON.3=1 ' Timer1 oscilator enable
    T1CON.1=0 ' Internal clock Fosc/4
    OT var PORTB.5 ' Entrada Obrir/Tancar diafragma
    OShutter var PORTC.0 ' Sortida obrir shutter
    TShutter Var PORTC.1 ' Sortida tancar shutter
    Estatus var bit ' Estatus=1 diafragma obert
    ShTemps var Word
    INICI:
    Pause 1000
    lcdout $fe, 1 ' Clear LCD
    Convertidor:
    on interrupt goto tickcount
    lcdout $FE, $80,"Test Timer1" ' Position cursor at home 1ª linea
    Pause 300
    SwitchOT:
    while OT=1
    goto convertidor
    wend
    Pause 20
    If estatus=0 then
    GOTO OpenShutter
    Else
    GOTO CloseShutter
    goto Convertidor
    OpenShutter:
    Oshutter=1
    pause 50
    Oshutter=0
    Estatus=1 ' Shutter obert
    INTCON.6=1 ' Enable all mask interrupts
    INTCON.7=1 ' Enable global interrupts
    T1CON.4=1 ' Prescaler timer=1:8
    T1CON.5=1 ' Prescaler timer=1:8
    PIE1.0=1 ' Enables TM1 overflow interrupt
    T1CON.0=1 ' start TM1 clock
    PIR1.0=0 ' Reset TM1 interrupt flag
    LCDOUT $fe,$C0+13,40,32,41 '32=Tot Blanc
    ShTemps=0
    LCDOUT $fe,$C0," "
    goto convertidor
    CloseShutter:
    TShutter=1
    Pause 50
    Tshutter=0
    Estatus=0 ' Shutter tancat
    T1CON.0=0 ' Stop Tm1 clock
    INTCON.6=0 ' Disable all mask interrupts
    INTCON.7=0 ' Disable global interrupts
    LCDOUT $fe,$C0+13,40,255,41 '255=Tot Negre
    goto convertidor
    disable
    Tickcount:
    ShTemps=ShTemps+1
    LCDOUT $fe,$C0,#ShTemps
    resume
    enable
    skimask's Avatar
    skimask Guest
    My suggestion...
    Get rid of the shutter code stuff...
    Make TMR1 work for you first! Make an LED blink at the rates you want according to how you set up the prescaler. That way you'll know the interrupt functions are functioning as they should...
    Then start adding things for measuring time and running a shutter.
    What about ADCON0?
    Turn off the WDT
    Mar 2006
    My suggestion...
    What about ADCON0?
    Turn off the WDT
    I wrote this new code trying to follow your hints but it does'nt work . I get a tick every 2.2 msec with a Prescaler (1:8) and the same value for prescaler (1:1)
    Inputs and outputs and LCD work OK
    The overflow time of TMR1 is always the same because the time externally controlled through leds is 27284 ticks every 60 sec -2.2 msec- and according to my numbers it should be about 524 msec for 4MHz and PS=1:8 so, I can not understand what happens.
    Any hint?
    -Francesc
    Here is new code:
    O var PORTB.5 ' Entrada Obrir diafragma
    ShTemps var Word
    T var PortB.6 'entrada tancar diafragma
    INICI:
    Pause 1000
    TShutter=1
    Pause 10
    Tshutter=0
    Estatus=0 ' diafragma tancat
    Convertidor:
    If Estatus=0 then
    GOTO SwitchO
    Goto SwitchT
    SwitchO: 'switch for start timer
    while O=1
    goto convertidor
    wend
    Pause 20
    If estatus=0 then
    GOTO OpenShutter
    goto Convertidor
    SwitchT: 'switch for stop timer
    while T=1
    goto convertidor
    wend
    Pause 20
    If estatus=1 then
    GOto CloseShutter
    goto Convertidor
    OpenShutter:
    Oshutter=1 ' Blink led for external control
    pause 20 ' Blink led for external control
    Oshutter=0 ' Blink led for external control
    LCDOUT $fe,$C0," "
    ShTemps=0
    TMR1L=0
    TMR1H=0
    T1CON.3=0 '
    goto convertidor
    CloseShutter:
    TShutter=1 ' Blink led for external control
    Pause 10 ' Blink led for external control
    Tshutter=0 ' Blink led for external control
    LCDOUT $fe,$C0,#ShTemps ' display
    goto convertidor
    disable
    Tickcount:
    ShTemps=ShTemps+1
    resume
    enable
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by fnovau View Post
    Turn off the WDT.
    Mar 2006
    Turn off the WDT.
    I get the same results ¡¡
    Mar 2006
    At last program begins to work when I place
    into Tickcount ISR giving overflow times of 65.8/132/263.6 and 524.7 msec according with Prescaler.
    WDT_ON or WDT_OFF apparently does not change results
    Tickcount:
    ShTemps=ShTemps+1
    resume
    enable
    Thank you Skimask for your help
    -Francesc
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 12:49
  2. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 16:07
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  4. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 01:31
  5. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 02:24
