There is no playback code in that ASM file. It contains only the bits required to reproduce that sound. You need to write code that will output those bits to you chosen i/o pins at the correct bitrate.
The bitrate (as specified by the ASM file) is 11025 bits/sec, so you need to write your code to do the same.
