SEROUT2 fails on newer 18F2610
Results 1 to 15 of 15
    Question SEROUT2 fails on newer 18F2610
    Hello,
    I've been programming 18F2610s for several years now without a problem.
    Now, I got a new batch of 18F2610s date coded 0804, and using the exact same code from several years it does not work. SEROUT2 sends out garbage.
    I have a couple of older PICs date coded 0427 and 0730 and they work just fine, but 12 newer ones just won't work.
    Is anybody aware of a silicon update that could affect SEROUT2 on this PIC?
    Is there a workaround for this?
    Any help will be greatly appreciated.
    Thanks, Gabriel
    Quote Originally Posted by gabrielg74 View Post
    Hello,
    Thanks, Gabriel
    Internal or external oscillator?
    External, 20MHz crystal.
    Tried 5 different boards with the new PIC (fails) and with the old one (works ok).
    Gabriel
    Gabriel
    Just looked at the ERRATA sheets from Microchip.
    Nothing specific to that particular issue, but a lot of things that could be tied into it.
    Suggest paging thru them to see if you can find anything.
    Which version of PBP are you using?
    PBP 2.4.6.0
    Already checked the Errata and could not find anything that could be causing this.
    Gabriel
    PBP 2.4.6.0
    Gabriel
    Well,,,,,,,,,,show the code. Maybe there's a bit changed in there somewhere.
  1. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 15:26
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  4. Serial communication fails after long pause
    By brid0030 in forum General
    Last Post: - 13th February 2008, 19:56
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 04:38
