Port Manipulation
Results 1 to 4 of 4
    Yes, after trying numerous things by using bit logic and then setting the pin directly I still see the same problem.
    Each time I set mutiple outputs on PortD my inputs start changing. I noticed the LEDs on the EasyPic board are dimly lit. It's the way I'm using the protoboard and not the bitlogic I was using.
    Bombay, India
    Have you set the TRISD register correctly?
  1. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 23:30
    Last Post: - 14th November 2008, 17:25
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
