Controlling switches with a PIC
Results 1 to 11 of 11
    Sep 2007
    Quote Originally Posted by TonyA View Post
    Would the 5V dc wire (connected to "C") be brought to ground when the pic pin is high?
    The 2n2222 is an NPN BJT transistor.
    See: http://en.wikipedia.org/wiki/2N2222
    Yes, when voltage is applied to the base, current will flow from C to E. When the base is low, there is no flow.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    Apr 2006
    Thanks for the help, I appreciate it.
    Would the 2n2222 work for my application? (i.e. just pulling a 5V wire to ground?) Which transistor would you recommend?
    Thanks again,
    TOny
    Thanks again,
    TOny
    Use the 2N2222. As long as you aren't pulling a zillion amps thru it, you'll be fine.
    Just make sure you read and understand how to do so...
    None!
    Just use the Tri-State output of the PIC.
    PORTB.0 = 0   ; Pin goes to gnd when not Tri-Stated
    TRISB.0 = 0   ; Output to Ground
    TRISB.0 = 1   ; Output Tri-Stated
    Added:
    If there's any possibility that the external 5V is higher than the PIC's 5V?
    Use PORTA.4 instead. It doesn't have the VDD voltage limit.<br>
    Apr 2006
    Darrel, and FalingTrea thanks. I was wondering about that. Thanks again.
    Tony
  1. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  2. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 11:21
  3. Controlling power to a PIC with another PIC
    By jswayze in forum Off Topic
    Last Post: - 28th May 2005, 20:44
  4. Serial Pic to Pic using HSER
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 14:16
