PIC18f2455 blink
Results 1 to 23 of 23
    I understand that DATA is upgraded version of EEPROM
    Quote Originally Posted by iugmoh View Post
    Maybe......There is a difference. Either I can't remember, or I can't put my finger on it at the moment.
    Of course there's always the chance that I just don't know
    I change the PIC16f877A with PIC18F452 and nothing is working , so I will learn every thing step by step of PIC18f452
    You really don't have to 'RELEARN' everything...because there really isn't anything to 'RELEARN'.
    There is a document somewhere at Microchip that describes some basic differences between the '877 and the '452 that might help you out...
    But...quite frankly, no code...not much help...'cause there just might be that one hidden thing that is stopping everything.
    Have you made blinky LED work on the '452 yet?
    And just because you've made it work on the '877 doesn't mean you can make it work on a '452....it should...but it doesn't.
    Oky thanks skimask for your information I will try to make blink lea and see the differents
    Question Blinking LED not working !
    I try this code for blinking led on PIC18f452 , but nothing happened, the led always off , I use in this circuit 4MHZ XT crystal , 10K connected to MCLR TO +5v:
    trisb=0
    portb=0
    portb=255
    Here is 18F452.INC file
    ;* 18F452.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2005 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 12/16/05 *
    ;* Version : 2.47 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F452, r = dec, w = -311, w = -230, f = inhx32
    INCLUDE "P18F452.INC" ; MPASM Header
    __CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    __CONFIG _CONFIG4L, _LVP_OFF_4L
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    Connect the LED to MCLR...does it work then?
    And let it run for at least 2 minutes.
    Does the LED on PortB.0 change state?
  1. Trouble with most basic BLINK on PIC 16F819
    By confusedperson in forum mel PIC BASIC Pro
    Last Post: - 16th April 2009, 21:46
  2. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 20:30
  3. Can't get blink circuit to work :(
    By Techbuilder in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 13:00
  4. I Just Can't Get it to Blink - 16F628
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 15:54
  5. 20Mhz crystal cause led to blink irreguarly
    By niknaksbarbeque in forum mel PIC BASIC Pro
    Last Post: - 16th April 2005, 11:35
