433.92 MHz dorrbell
Results 1 to 7 of 7
    Jan 2008
    I can see the output on the scope but i donīt understand how to translate it o PBP code and send it via the parallax transmitter.
    Dec 2005
    I have no idea about the Parallax transmitter (maybe you should be asking on a Parallax forum) but you need to measure the durations of the pulses and spaces and just duplicate them on output. With a PIC and the less expensive transmitters I prefer, I just use PulsOut, as demonstrated in my example in the Code Examples forum.
    Jan 2008
    The parallax RF modules i based on the LINX chipīs
    Yes i can se the output on a scope but how do i translate it to a PBP code?
    Quote Originally Posted by Fredrick View Post
    Hi Fredrick,
    I believe you will have to modulate it in some fashion, easiest and noisiest way is AM, FM is better, less noise, and finally you could pulse the output, likely the least reliable.
    Mar 2004
    UK-Midlands
    Hi Fredrick,
    The code is hopefully not to critical....
    The way I would start is to measure the smallest pulse and use this as the clock.
    Set up one of the timers to interupt at this interval. Then just clock through 8 bit (byte) numbers that match the waveform.
    ie. $8A = 10001010
    BobP
  1. TSA5512/5511 code for PIC16F877/84
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 24th August 2013, 07:16
  2. Setting up a 12F683 to run at 20 Mhz
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 03:46
  3. Resonator Suppliers for 40 MHz?
    By mcphill in forum General
    Last Post: - 23rd January 2009, 03:05
  4. bootloader file 10 mhz
    By emmett brown in forum mel PIC BASIC Pro
    Last Post: - 29th September 2006, 01:33
  5. 20 MHz + PLL vs 48MHz
    By Demon in forum General
    Last Post: - 31st July 2006, 13:02
