Multiple if then optimization
Results 1 to 36 of 36
    Jan 2008
    Selm, Germany
    Smile Its Guru time
    Hi Darrel,
    looks impressive to me like a motorcycle to a small boy.....
    Whats this command:
    Uin = Uin */ 124 ; same as (* 100 / 207)
    the above means two mathematic orders in one? something like shifting bits?
    there would be a small mistake but thats totally acceptable because the bargraph is that crude which is really fine enough.
    will test that of course although there should be no need.....
    regards
    Mugel
    The */ operator first multiplies the 2 values (Uin * 124).
    Then it discards the low byte, and returns the rest.
    So effectively, it divides the result by 256, without having to do the divide part.
    100 / 207 = 0.48309178
    124 / 256 = 0.484375 ; not exact, but pretty close
    You're correct that there are small differences between the 2 formulas, but the error is less than +/- 1. And, you will never see a difference with the resolution of a 16 block bargraph.
    And, there probably is a need to test it.
    I was using a 16F877 with a 4x20 LCD. Could have missed something for your 16F628A and 1x16 LCD.
    Question
    Hi, Darrel
    Could you tell us for LCD Initialization at powerup ...If Uin first value is > 10 ... I do not see any ???
    you just suppose exhaust is air filled ???
    I'm not sure what you mean Alain.
    If the first value is > 10, it will just draw the bargraph like normal.
    It doesn't do anything until a serial byte is received.
    Hi,Darrel
    What I ment is you initialize the LCD ... ONLY if the value is < 10 ... ( when writing TOO LOW )
    What if you stop the engine and start it again ??? ... first value will be > 10 , due to the exhaust gases still in the exhaust tubing ... and I do not see any LCDOUT $FE,1 in this figure.
    Exhaust gases might still be in the tubing, but I wonder how quickly the sensor will cool off and not make a decent output. In my experience, those things cool off fairly quick. But then again, the 3/4 wire ones heat up pretty fast too...
    Jan 2008
    Selm, Germany
    Talking Lambda probes
    Hi Guys,
    now thats stuff I´m into ! Those lambda probes are reacting pretty fast when hot, about the whole scale from too lean to too rich in half a second . Reliable results will be in after about half a minute with a cold engine starting when using 4 wire probes, 2 minutes or more with one wire probes and those one wire probes without heating are useless for idle control, heats too low. You can see lots of hidden stuff like choke or accelerator pump work or fuel cutoff when stepping off the gas. Funny to watch but most times absolut neccessary for the first setup.
    Oh, you mean the "Clear Screen".
    Since it writes to all 16 characters on each pass, I used "Home Cursor" ($FE,2) instead of "Clear Screen" ($FE,1) to prevent blinking of the display during updates.
    Or, if you're referring to the Power-On initialization that gets rid of the black blocks and makes the LCD work in the first place .... Mugel didn't have any specific initialization sequences in his original program and reported it to be working. So I assumed his display didn't need it.
    The first character sent to the LCD will cause PBP to initialize the display (if it hasn't already). It doesn't have to be $FE,1.
    Feb 2003
    Salt Lake City, Utah USA
    A Different Approach (317 Words ... without most of Darrel's amazing methods, which means there is room for more codesavings)
    ;@__config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    CMCON=%00000111
    DEFINE DEBUG_BAUD 2400   'Debug baud rate
    DEFINE DEBUGIN_REG PORTB 'Debugin pin port
    DEFINE DEBUGIN_BIT 0     'Debugin pin bit
    DEFINE DEBUGIN_MODE 1    'Debugin mode: 0 = True, 1 = Inverted
    ;DEFINE OSC 4
    xB0 var byte     ; SERIAL IN IS A BYTE SO MAKE IT A BYTE
    ;inputData var word ' variable to receive data into
    ' START OF MAIN PROGRAM
    CMCON = 7 ' RA0-RA3 are digital I/O
    TRISA = 0 ' PORT A is output
    TRISB = 1 ' RB0 is Input others output
    MAIN:
    DEBUGin [xB0]
    ;B0 = 100 * B0  ; why do these two lines?  B0 is already a Byte so work with Bytes
    ;Uin = B0 / 207  ;
    LCDOUT $FE, 1
    If xB0 < 21 then
        LCDOUT "TOO LOW"
        GOTO OUT
    IF xB0 < 34 then BARGRAPH1
    IF xB0 < 42 then BARGRAPH2
    IF xB0 < 52 then BARGRAPH3
    IF xB0 < 63 then BARGRAPH4
    IF xB0 < 73 then BARGRAPH5
    IF xB0 < 92 then BARGRAPH6
    IF xB0 < 112 then BARGRAPH7
    IF xB0 < 131 then BARGRAPH8
    LCDOUt $FE, $C0
    IF xB0 < 152 then BARGRAPH9
    IF xB0 < 170 then BARGRAPH10
    IF xB0 < 181 then BARGRAPH11
    IF xB0 < 191 then BARGRAPH12
    IF xB0 < 201 then BARGRAPH13
    IF xB0 < 210 then BARGRAPH14
    IF xB0 < 220 then BARGRAPH15
    IF xB0 < 230 then BARGRAPH16
    LCDOUT $FE,$C0,"TOO RICH"
    goto OUT
    BARGRAPH16:
    gosub p255
    BARGRAPH15:
    gosub p255
    BARGRAPH14:
    gosub p255
    BARGRAPH13:
    gosub p255
    BARGRAPH12:
    gosub p255
    BARGRAPH11:
    gosub p255
    BARGRAPH10:
    gosub p255
    BARGRAPH9:
    gosub p255
    LCDOUT $FE, $80   ; line 1
    BARGRAPH8:
    gosub p255
    BARGRAPH7:
    gosub p255
    BARGRAPH6:
    gosub p255
    BARGRAPH5:
    gosub p255
    BARGRAPH4:
    gosub p255
    BARGRAPH3:
    gosub p255
    BARGRAPH2:
    gosub p255
    BARGRAPH1:
    gosub p255
    OUT:
    Pause 5
    goto MAIN
    p255:
    lcdout 255
    END ' End of program
    [disclaimer] untested [/disclaimer]
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  2. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 15:13
  3. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 23:47
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 17:02
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 22:07
