Multiple if then optimization
Results 1 to 36 of 36
    @      __config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    Include "modedefs.bas"
    nbpatterns var byte:uin var word:cmcon=7:trisa=0:trisb=1
    main: serin portb.0,n2400,uin:uin=(uin*100)/207:lcdout $fe,1,"TOO ":if uin<10 then lcdout "LOW":goto show
    IF Uin > 110 THEN LCDOUT "HIGH": GOTO Show
    lookdown2 uin,<[11,16,20,25,30,35,44,54,63],nbpatterns:lcdout $fe,1,rep 255\nbpatterns
    if uin > 62 then
    lookdown2 uin,<[ 63,73,82,87,92,97,101,106,111], NbPatterns
    lcdout $fe,1,rep 255\ 8,$fe, $c0, rep 255\ nbpatterns
    Show:     Pause 5:goto main
    END ' End of program
    13 LINES!
    Jan 2008
    Selm, Germany
    Default code minimum
    Hi Skimask,
    yeah will try that too, never worked around the lookdown commands...will see how it works
    sincerely
    Mugel
    Talking
    13 LINES!
    Hi, Ski
    That's way too hard for my old eyes !!! Lol ...
    at second look ... I've seen that somewhere before, but Where ??? ...
    Hi, Ski
    Might even be a few words shorter on code!
    Or at least a few colons longer.
    Jan 2006
    Istanbul
    13 lines is not the case ;
    But, it is only 2 words smaller then Alain's.
    Come on Ski, saved 2 words only ???
    Quote Originally Posted by sayzer View Post
    It's monday! What'd you expect?
    Wait 'till DT comes online...
    Figure maybe down to...what...25 words total?
    Jan 2008
    Selm, Germany
    Talking Test Result
    Welcome dear ladies and gentlemen to todays code shrinking contest!
    Now I testet all 3 programms and have to tell the outcome:
    1.: Dear Mr. Sayzer, theres a small bug in your code, it shows only "Too High" or "Too Low"
    2.: Dear Mr. Acetronic: Excellent work, runs flawlessly.
    3.: Dear Mr. skimask: Full OK also !
    Applause to all three contestants.
    Besides: tons (ok kilos) of learning opportunities for me.
    Thanks you Gurus!
    Mugel
    Thanks for the vote of confidence ski.
    But sadly, all I could muster was a slim 335 words
    <font color="#000000"><b>CMCON </b>= <font color="#800000"><b>7                </b></font><font color="#0000FF"><b><i>' Disable Comparators
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUG_BAUD </b><font color="#800000"><b>2400   </b></font><font color="#0000FF"><b><i>'Debug baud rate
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUGIN_REG PORTB </b><font color="#0000FF"><b><i>'Debugin pin port
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUGIN_BIT </b><font color="#800000"><b>0     </b></font><font color="#0000FF"><b><i>'Debugin pin bit
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>DEBUGIN_MODE </b><font color="#800000"><b>1    </b></font><font color="#0000FF"><b><i>'Debugin mode: 0 = True, 1 = Inverted
    </i></b></font><b>Uin       </b><font color="#008000"><b>VAR WORD
    </b></font><b>B0        </b><font color="#008000"><b>VAR BYTE
    </b></font><b>BarCount  </b><font color="#008000"><b>VAR BYTE
    </b></font><b>BarValue  </b><font color="#008000"><b>VAR WORD
    </b></font><b>MsgAddr   </b><font color="#008000"><b>VAR WORD
    </b></font><b>Carry     </b><font color="#008000"><b>VAR </b></font><b>STATUS</b>.<font color="#800000"><b>0        </b></font><font color="#0000FF"><b><i>; Hardware carry flag
    </i></b></font><font color="#008000"><b>GOTO </b></font><b>Main                     </b><font color="#0000FF"><b><i>; Jump over data
     </i></b></font><b>BarSteps</b>:  <b>POKECODE   </b><font color="#800000"><b>10</b></font>,<font color="#800000"><b>15</b></font>,<font color="#800000"><b>19</b></font>,<font color="#800000"><b>24</b></font>,<font color="#800000"><b>29</b></font>,<font color="#800000"><b>34</b></font>,<font color="#800000"><b>43</b></font>,<font color="#800000"><b>53</b></font>,<font color="#800000"><b>62</b></font>,<font color="#800000"><b>72</b></font>,<font color="#800000"><b>81</b></font>,<font color="#800000"><b>86</b></font>,<font color="#800000"><b>91</b></font>,<font color="#800000"><b>96</b></font>,<font color="#800000"><b>100</b></font>,<font color="#800000"><b>105
    </b></font><b>_BarSteps   </b><font color="#008000"><b>CON </b></font><b>EXT           </b><font color="#0000FF"><b><i>; create a PBP constant that points to the Table
     </i></b></font><b>TooLow</b>:  <b>POKECODE </b><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>1</b></font>,<font color="#FF0000">&quot;TOO LOW &quot;</font>,<font color="#800000"><b>0
    </b></font><b>_TooLow   </b><font color="#008000"><b>CON </b></font><b>EXT             </b><font color="#0000FF"><b><i>; PBP constant pointing to the &quot;Too Low &quot; string
     </i></b></font><b>TooRich</b>: <b>POKECODE </b><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0</b></font>,<font color="#FF0000">&quot;TOO RICH&quot;</font>,<font color="#800000"><b>0
    </b></font><b>_TooRich  </b><font color="#008000"><b>CON </b></font><b>EXT             </b><font color="#0000FF"><b><i>; PBP constant pointing to the &quot;Too Rich&quot; string
    </i></b></font><b>FlashSize </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#008000"><b>ASM
       </b></font><font color="#000080">ifdef BSR
    FlashSize = 2                 </font><font color="#0000FF"><b><i>; 18F has byte addressing (2)
       </i></b></font><font color="#000080">else
    FlashSize = 1                 </font><font color="#0000FF"><b><i>; 12F/16F has words (1)
       </i></b></font><font color="#000080">endif
    </font><font color="#008000"><b>ENDASM
    </b></font><b>MidChar   </b><font color="#008000"><b>CON </b></font><b>EXT             </b><font color="#0000FF"><b><i>; MidChar is the border between
    </i></b></font><font color="#000080">@MidChar = 8 * FlashSize      </font><font color="#0000FF"><b><i>; 8 char segments of the 1x16 LCD being used
    </i></b></font><b>Main</b>:
        <font color="#008000"><b>DEBUGIN </b></font>[<b>Uin</b>.<b>LowByte</b>]     <font color="#0000FF"><b><i>; Serial Input
        </i></b></font><b>Uin </b>=  <b>Uin </b>*/ <font color="#800000"><b>124         </b></font><font color="#0000FF"><b><i>; same as (* 100 / 207)
        </i></b></font><font color="#008000"><b>LCDOUT </b></font><font color="#800000"><b>$FE</b></font>, <font color="#800000"><b>2             </b></font><font color="#0000FF"><b><i>; LCD Home Cursor
        </i></b></font><font color="#008000"><b>FOR </b></font><b>BarCount </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>TO </b></font>(<font color="#800000"><b>15 </b></font>* <b>FlashSize</b>) <font color="#008000"><b>STEP </b></font><b>FlashSize
            </b><font color="#008000"><b>IF </b></font>(<b>BarCount </b>= <b>MidChar</b>) <font color="#008000"><b>THEN LCDOUT </b></font><font color="#800000"><b>$FE</b></font>,<font color="#800000"><b>$C0  </b></font><font color="#0000FF"><b><i>; Second half of 1x16 LCD
            </i></b></font><b>PEEKCODE </b>(<b>_BarSteps</b>+<b>BarCount</b>),<b>BarValue       </b><font color="#0000FF"><b><i>; Get BarValue from Table
            </i></b></font><b>R0</b>.<b>LowByte </b>= <b>Uin</b>.<b>LowByte </b>- <b>BarValue
            </b><font color="#008000"><b>IF </b></font><b>Carry </b><font color="#008000"><b>THEN                                </b></font><font color="#0000FF"><b><i>; Uin &gt;= BarValue
                </i></b></font><font color="#008000"><b>LCDOUT </b></font><font color="#800000"><b>255                               </b></font><font color="#0000FF"><b><i>;  show a Full char
            </i></b></font><font color="#008000"><b>ELSE                                         </b></font><font color="#0000FF"><b><i>; Uin &lt; BarValue
                </i></b></font><font color="#008000"><b>LCDOUT </b></font><font color="#FF0000">&quot; &quot;                               </font><font color="#0000FF"><b><i>;  show a blank
            </i></b></font><font color="#008000"><b>ENDIF
        NEXT </b></font><b>BarCount
        R0</b>.<b>LowByte </b>= <b>Uin</b>.<b>LowByte </b>- <font color="#800000"><b>10                    </b></font><font color="#0000FF"><b><i>; if Uin &lt; 10
        </i></b></font><font color="#008000"><b>IF </b></font>!<b>Carry </b><font color="#008000"><b>THEN </b></font><b>MsgAddr </b>= <b>_TooLow </b>: <font color="#008000"><b>GOSUB </b></font><b>ShowMsg
        R0</b>.<b>LowByte </b>= <b>Uin</b>.<b>LowByte </b>+ <font color="#800000"><b>145                   </b></font><font color="#0000FF"><b><i>; if Uin &gt; 110
        </i></b></font><font color="#008000"><b>IF </b></font><b>Carry </b><font color="#008000"><b>THEN </b></font><b>MsgAddr </b>= <b>_TooRich </b>: <font color="#008000"><b>GOSUB </b></font><b>ShowMsg
    </b><font color="#008000"><b>GOTO </b></font><b>Main
    </b><font color="#0000FF"><b><i>;=============================================================================
    </i></b></font><b>ShowMsg</b>:
        <b>PEEKCODE MsgAddr</b>, <b>B0
        </b><font color="#008000"><b>IF </b></font><b>B0 </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>THEN RETURN
        LCDOUT </b></font><b>B0
        MsgAddr </b>= <b>MsgAddr </b>+ <b>FlashSize
    </b><font color="#008000"><b>GOTO </b></font><b>ShowMsg
    </b>
    cheers,
    Jan 2008
    Selm, Germany
    Smile Its Guru time
    Hi Darrel,
    looks impressive to me like a motorcycle to a small boy.....
    Whats this command:
    Uin = Uin */ 124 ; same as (* 100 / 207)
    the above means two mathematic orders in one? something like shifting bits?
    there would be a small mistake but thats totally acceptable because the bargraph is that crude which is really fine enough.
    will test that of course although there should be no need.....
    regards
    Mugel
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 16:18
  2. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 16:13
  3. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 8th May 2007, 00:47
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 18:02
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
