Multiple if then optimization
Results 1 to 36 of 36
    Jan 2008
    Selm, Germany
    Default Sting!
    Hey Girls & Guys,
    seems I poked into a bees nest.... I will try those codes in the evening (10 hrs from now).
    Youre really helpful.
    How about a code for extern interrupt that triggers a 1 ms high port after a delay found in a lookdown/case/if then row list? from 3 to 600 Hz of course......to get a constant phase shift between trigger and output.....
    Its oughta be real fast!! 20MHz 16F628A preferred
    "On interrupt" gets 180° phase shift (maximum limit) at 200 Hz.....
    I dunno how to integrate a variable delay into DTs instant interrupts....
    Smile
    Quote Originally Posted by Mugelpower View Post
    Could you explain that better ???
    You're asking for a PBP written electronic ignition here ...
    don't you think you abuse ... just a little bit !!!
    Have an eye here ... : http://a110.free.fr/SPIP172a110/arti...?id_article=23
    Ok, assembler ... but kit or scratch realizable, and the forum offers a Huge help ...
    PS: I'm working on a full PBP version ... but Assembler interrupts can't be avoided !!!
    Jan 2008
    Selm, Germany
    Red face Ignition help
    Hi Acetronics,
    yeah, in Principle thats that. BUT: thats french (ARGL-GARG!!) and I donīt understand 2% of it.
    And: I have to modify the code it myself fromtime to time which could only be done if Iīm knowing quite a lot about the code. Man, thats a BIG FISH to swallow for an oldschool mechanic. Learning programming, trying to avoid asm, learning that asm couldnīt be avoided...... ARGL-GARG !
    Wink
    Generally speaking ...
    Using PbP do not "protect" you from learning assembler ...it's a real "plus" to see the ASM result of your programming ...
    and overall understand what's really happening, and how ...
    Now about Ignition ... it's simple: you have an asm program to use with MPLAB , and a " Table generator " program ( in QBasic or, more recently EXCEL), just to load your timing values.
    So, there are special knowledge of assembler needed ...
    For French ... aha ... just think I spent a year in Berlin ( Yr 1990 ), and had to dig out my German school knowledge ... Euuuuhhhh, I'm also an old Mechanics ( and Thermics ) guy ...
    Just Follow the scheme and components list ... you'll have done 90% of the work. ... on the Forum, we ALSO Compute tables for ... how to tell it ??? .... E.T.s ?
    You also have this link ... in English :
    http://www.transmic.net/index.htm
    But ... not so good as ours ... yeah !!!
    PS for Sayzer ...: I found a Turkish > French / French > Turkish free dictionnary on the Web; I do Hope you appreciate the effort ( LoL ...)
    Jan 2008
    Selm, Germany
    Wink english link
    Hi Acetronics,
    youve been to Germany? thats been a dark time I guess.....haha.
    I already Knew the CDI transmic link but they have only the .hex file GRRRR....!
    I found this too:
    http://www.angelfire.com/ia/lfb/Pgbosch.html
    but thats way more code and unneccessary extra sparks.
    and by the way.....isnīt it more fun to get to the finish by ourselfs?
    We'll have to close this Ignition thread ... Because HS ...
    a last one ...
    http://denis.tauvel.free.fr/index.htm
    << youve been to Germany? thats been a dark time I guess.....haha. >>
    no,no ... was a wonderful year ... indeed !!! Berliners are really smart people !
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 16:18
  2. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 16:13
  3. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 8th May 2007, 00:47
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 18:02
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
