Multiple if then optimization
Results 1 to 36 of 36
    Jan 2008
    Selm, Germany
    Wink Multiple if then optimization
    Hi Gurus of Picland,
    Iīm building a Lambdatester that flattens somewhat out the hard jump in output voltage between lean and rich.
    wrote a code that works. Fine, and fast enough because theres hardly need for speed.
    Way of simple code for Picdummies like me .
    But if an oldschool mechanic like me looks at it even he knows that theres plenty room for codesaving.
    You Gurus fall down your chairs laughing and crying at the same time, I know.
    '* Name : Analogbargraph1(16F628A).BAS *
    '* Author : M.David *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 28.02.2008 *
    '* Version : 1.0 *
    '* Notes : needs 12F675 for Lambdatesting device and LCD 1X16 *
    '* : input 0.1 - 1.1 Volts in GPIO.0 *
    '* : needs ADCserout(12F675).bas *
    ' DEFINITIONS
    @__config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    Include "modedefs.bas"
    CMCON=%00000111
    Uin var word
    B0 VAR word ' Cnt is a word variable
    inputData var word ' variable to receive data into
    ' START OF MAIN PROGRAM
    CMCON = 7 ' RA0-RA3 are digital I/O
    TRISA = 0 ' PORT A is output
    TRISB = 1 ' RB0 is Input others output
    Serin PORTB.0,N2400,B0
    B0 = 100 * B0
    Uin = B0 / 207
    gosub bargraph
    Pause 5
    bargraph:
    if Uin < 10 then LCDOUT $FE,1,"TOO LOW"
    if (Uin > 10) and (Uin <= 15 ) then
    LCDOUT $FE,1,255
    if (Uin > 15) and (Uin <= 19 ) then
    LCDOUT $FE,1,255,255
    if (Uin > 19) and (Uin <= 24 ) then
    LCDOUT $FE,1,255,255,255
    if (Uin > 24) and (Uin <= 29 ) then
    LCDOUT $FE,1,255,255,255,255
    if (Uin > 29) and (Uin <= 34 ) then
    LCDOUT $FE,1,255,255,255,255,255
    if (Uin > 34) and (Uin <= 43 ) then
    LCDOUT $FE,1,255,255,255,255,255,255
    if (Uin > 43) and (Uin <= 53 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255
    if (Uin > 53) and (Uin <= 62 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255
    if (Uin > 62) and (Uin <= 72 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255
    if (Uin > 72) and (Uin <= 81 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255
    if (Uin > 81) and (Uin <= 86 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255
    if (Uin > 86) and (Uin <= 91 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255
    if (Uin > 91) and (Uin <= 96 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255
    if (Uin > 96) and (Uin <= 100 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255,255
    if (Uin > 100) and(Uin <= 105 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255,255,255
    if (Uin > 105) and(Uin <= 110 ) then
    LCDOUT $FE,1,255,255,255,255,255,255,255,255,$FE,$C0,255, 255,255,255,255,255,255,255
    if Uin > 110 then
    LCDOUT $FE,$C0,"TOO RICH"
    END ' End of program
    on the other hand it works and shows how good and fast the combination of pics and PBP works.
    Any Ideas? maybe case select or lookdown or whatever?
    sincerely
    Mugel
    The Obvious Command is ... SELECT CASE
    Note here you check Twice your values ... a better test arrangement looks like :
    IF Value < 19
    IF Value < 24
    IF Value < 29
    also can be used ...
    IF Value < 10 THEN LCDOUT $FE, 1, "TOO LOW"
    LOOKDOWN2 Value , < ,[ 10,15,19,24,29, ....], NbPatterns
    LCDOUT $FE, 1, REP 255\ NbPatterns
    Which is ... Somewhat shorter ( from the listing point of view ...)
    North Norfolk UK
    hi Mugel,
    I don't know where all the gurus are today, but in thier absence I glanced at your post and thought you might like to take a look at the >select case< command. As all your conditions are sequentially discrete then this might be worth considering.
    The trouble with long lists of if..thens are that once the condition is met (let say at the begginning of the list) then the program continues to chunder through all the remaining if...thens, whereas select case will exit at >end case< once the condition is met. Be careful though if your conditions are not discrete ,then you will have to arrange the cases in order of preference.
    As to code space, I cannot remember but you could quickly swap the code over and see which is smaller.
    Duncan
    Sep 2007
    USA, CA
    Quote Originally Posted by duncan303 View Post
    The trouble with long lists of if..thens are that once the condition is met (let say at the beginning of the list) then the program continues to chunder through all the remaining if...thens, whereas select case will exit at >end case< once the condition is met. Be careful though if your conditions are not discrete ,then you will have to arrange the cases in order of preference.
    Duncan
    The way around this is to nest them, and put the largest value at the top. For instance, instead of this...
    if a < 5 then...
    endif...
    if a < 10 then...
    endif...
    You do this for nesting:
    if a < 10 then
    if a < 5 then
    code here...
    code here...
    or this for simple and fast testing:
    if a < 10 then
    code here...
    goto SkipTests
    if a < 5
    code here...
    SkipTests:
    Using this method skips all of the IF's if the most extreme condition isn't true. All of this depends upon the assumption that the value of "a" isn't changed within any of the conditional statements.
    Default 1 old mechanic to another
    Hi Mugelpower,
    Have you tried Darrel's Bargraph routine?
    http://www.picbasic.co.uk/forum/showthread.php?t=2359
    North Norfolk UK
    Quote Originally Posted by tenaja View Post
    I am curious if this would compile with the list that Mugel has created, some 20 nested if…then...Else’s on a 16F device?
    Duncan
    Sep 2007
    USA, CA
    It should. I believe it just uses goto's, no stack use.
    Jan 2008
    Selm, Germany
    Cool 20 if then
    yes the 20 if then work, no problem. Assembling took maybe 3 times longer then those blinky codes and it uses nearly 3/5 of the code space in my 16F628..but works flawlessly.
    to Joe:
    oh man I tried to use DTs bargraph routines but only got the error "coulndīt open bargraph.bas" or something. Copied it in a "dozen" directories around the main PBP main and my project directories...didnīt work, always the same error.
    But I uses DTs instant interrupt blinky program and that worked....so I donīt know a bone about how to work around "include" problems.
    On the other my bargraph is quite crude with its big bars....but a fine bargraph isnīt an option here...way to hard to see while driving the car or bike, you need only sort of lean/rich tendencies and the lambda sensor it VERY jumpy around the stochiometric area.
    8 leds would do but I did it mainly because of 3 reasons:
    1.: I COULD do it.......with a little help of my friends....greetings to you all!
    2.: One of my employees is sort of colour blind and wanted something to recocnize
    without colours.
    3.: we do a lot around sportscars engines and we test drive them mainly when the sun shines and a LED bargraph is hard to read while driving 100km/h in corners and the sun shining all over....
    Yeah......Iīm telling junk. Here in Germany the sunīs just a rumour you know, seen last time in june 2007 or so....
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 16:18
  2. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 16:13
  3. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 8th May 2007, 00:47
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 18:02
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
