Port Manipulation
Results 1 to 4 of 4
    Default Port Manipulation
    I have a port which has the first 4 pins as inputs and the second 4 pins as outputs.
    Reading the inputs and the outputs is pretty easy as I just masked them such as:
    DigIn = (PortD & $F) 'Lower 4 bits
    DigOut = (PortD >> 4) 'Upper 4 bits
    Now I want to change the outputs, so say I write:
    NewOuts = 240
    PortD = NewOuts 'Turns on all the upper 4 bits.
    This works fine, but I think it's automatically turning my lower 4 pins into outputs?
    How is the best way to do this?
    PortD = PortD OR NewOuts
    Feb 2003
    Salt Lake City, Utah USA
    No - it does not affect the lower 4 pins if they are inputs ... the value on the inputs are what they are and not affected by the writes to the port. Writing to the port also does not affect the TRIS register unless you have errors in your code.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Yes, after trying numerous things by using bit logic and then setting the pin directly I still see the same problem.
    Each time I set mutiple outputs on PortD my inputs start changing. I noticed the LEDs on the EasyPic board are dimly lit. It's the way I'm using the protoboard and not the bitlogic I was using.
    Bombay, India
    Have you set the TRISD register correctly?
  1. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 23:30
    Last Post: - 14th November 2008, 17:25
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
