Need help with debug
Results 1 to 3 of 3
    Mar 2004
    Default Need help with debug
    I have used Debug before and I understand how to use it, It works very well. I am using it to send the value of 3 variables out to a PC.
    I need a little help formating the screen for it to look good.
    When I have the following in a loop I get a messy scroll of repeated messages down the screen.
    debug "Current Voltage =",vc,10,13
    debug "Start Voltage =",vst,10,13
    debug "Stop Voltage =",vsp,10,13
    Current Voltage =12
    Start Voltage =11
    Stop Voltage = 14
    Current Voltage =12
    Start Voltage =11
    Stop Voltage = 14
    Current Voltage =12
    Start Voltage =11
    Stop Voltage = 14
    etc
    If I add debug 12 in as well I get only the 3 lines of information and it does not repeat all down the screen but as it refreshes it clears the screen so the effect is a high speed flicker.
    Can anyone tell me if there is a way to arrow up, down, left, right with debug?
    This might be what you want, ANSI Escape Sequences...
    The table obviously doesn't cut/paste correctly. But if you Google the term mentioned above, you should be able to find the up/down/left/right arrow functions that you want.
    Name Escape Code Hexadecimal Description
    Reset
    Device
    <ESC>c $1B $63 Resets all terminal settings to default.
    Enable Line
    Wrap
    <ESC>[7h $1B $5B $37
    $68
    Enables wrapping text to the next line if text is longer than
    the display area.
    Disable
    Line Wrap
    <ESC>[7l $1B $5B $37
    $6C
    Disables wrapping text; text will be clipped if longer than
    display area.
    Cursor Home <ESC>[H $1B $5B $48 Moves the cursor to the home position (upper left hand
    corner).
    Cursor
    Position
    <ESC>[{ROW};
    {COL}H
    $1B $5B
    ${ROW} $3B
    ${COL} $48
    Sets the position of the cursor at ({ROW}, {COL}).
    Cursor Up <ESC>[{NUM}A $1B $5B
    ${NUM} $41
    Moves the cursor up {NUM} rows;
    {NUM} defaults to 1 if omitted.
    Cursor Down <ESC>[{NUM}B $1B $5B
    ${NUM} $42
    Moves the cursor down {NUM} rows;
    Cursor Left <ESC>[{NUM}D $1B $5B
    ${NUM} $44
    Moves the cursor left {NUM} columns;
    Cursor
    Right
    <ESC>[{NUM}C $1B $5B
    ${NUM} $43
    Moves the cursor right {NUM} columns;
    Save Cursor <ESC>[s $1B $5B $73 Saves the current cursor position.
    Restore
    Cursor
    <ESC>[u $1B $5B $75 Restores the previously stored cursor position.
    Erase End
    of Line
    <ESC>[K $1B $5B $4B Erases from the current cursor position to the end of the
    current row.
    Erase Start
    of Line
    <ESC>[1K $1B $5B $31
    $4B
    Erases from the start of the current row to the current
    cursor position.
    Erase Line <ESC>[2K $1B $5B $32
    $4B
    Erases the entire current row.
    Erase Down <ESC>[J $1B $5B $4A Erases from the current row down to the bottom of the
    screen.
    Erase Up <ESC>[1J $1B $5B $31
    $4A
    Erases from the current row to the top of the screen.
    Erase
    Screen
    <ESC>[2J $1B $5B $32
    $4A
    Erases the entire screen and moves the cursor to the home
    position.
    Scroll All <ESC>[r $1B $5B $72 Enables scrolling for the entire display.
    Scroll
    Section
    <ESC>[{SRT};
    {END}r
    $1B $5B
    ${SRT} $3B
    ${END} $72
    Enables scrolling only for rows {SRT} to {END}.
    Scroll Down <ESC>D $1B $44 Scrolls the display down one line.
    Scroll Up <ESC>M $1B $4D Scrolls the display up one line.
    Attribute
    Mode set
    <ESC>[{ATR1};
    ...;{ATRn}m
    $1B $5B
    ${ATR1} $3B
    ... $3B
    ${ATRn} $6D
    Sets multiple display attribute settings; any number can be
    set. ATRn may be any of the following values:
    Standard
    Values for
    Attribute
    Mode Set
    0 Reset Attributes
    1 Bright
    2 Dim
    4 Underscore
    5 Blink
    7 Reverse
    8 Hidden
    Foreground Colors
    30 Black
    31 Red
    32 Green
    33 Yellow
    34 Blue
    35 Magenta
    36 Cyan
    37 White
    Background Colors
    40 Black
    41 Red
    42 Green
    43 Yellow
    44 Blue
    45 Magenta
    46 Cyan
    47 White
    Mar 2004
    Thanks Skimask.
    That was exactly what I was looking for. A few mor hours and it will be looking sweet.
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. Wireless using debug.
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 15:53
  3. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
