WRITE REAR eeprom Address ????'s
Results 1 to 3 of 3
    Jan 2007
    Houston, TX
    Default WRITE REAR eeprom Address ????'s
    Hello,
    I would like to know how to put the Address (for WRITE, READ command) in a for loop such that I can write once to adress 0, and then roll into adress 1 and so on. I have tried creating am variable but an not able to do this. Basically I am reading a POT 10x a second, sampling the data once and storing that sample in my eeprom, then reading the values back out to my LCD. I would like to use all 256 bytes of space in my eeprom while data logging.
    It's probably a dumb question but....?
    here is the snippet of my code that does work but is obviously a space waster
    loop1:
    LCDOUT 254,1
    for a = 0 to 20
    ADCIN 0, Value
    wriTE 0, Value
        y = ( Value *100 ) / 51   'divided down from * 255 / 130
        LCDOUT 254,Row1,"LOG SENSOR ",DEC1 (y / 100 ),".",DEC2 ( y // 100 )," VDC"
        lcdout 254,Row3+2, "0......|......5"
        ; syntax- BARgraph   Value, Row, Col, Width, Range, Style
        @         BARgraph  _Value,   2,   2,    15,   255,  lines
        next a
        'FIRST DATA SAMPLE
    for b = 0 to 20
    ADCIN 0, Value
    wriTE 1, Value
        next b
        'SECOND DATA SAMPLE
    for c = 0 to 20
    ADCIN 0, Value
    wriTE 2, Value
        next c
        'THIRD DATA SAMPLE
    for d = 0 to 20
    ADCIN 0, Value
    wriTE 3, Value
        next d
    Padawan-78
    The way you do it right now write 20 time on the same EEPROM adress... well your eeprom wil wear out pretty fast huh?
    Anyways, several way, the first that spring to mind is..
    For EEPAddr=0 to 255
        for d = 0 to 20
            ADCIN 0, Value
            next
        wriTE EEPAddr, Value
        next
    LCDOUT $FE,  1, "Thanks for shopping here",_
           $FE,$C0, "Come again :o)"
    HTH
    Jan 2007
    Houston, TX
    Good call on the Eeprom wearing out fast.
    Thanks for the help Mister E I will give it a try!
    Padawan-78
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  3. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
