SERIN & Timeout
Results 1 to 5 of 5
Thread: SERIN & Timeout
    Hangover, Germany
    Unhappy SERIN & Timeout
    I realize a projekt with a 868MHz-sender, which acts like a home-sign.
    The sender acts OK, but the receiver makes me worry....
    I don't use the internal Hardware-UART of the 16F872 (so far)...
    I use the SERIN-command. It works ...
    But if the sender is off, the receiver gets a lot of noise, so the Timeout of the SERIN-Command will not work, it restarts while it gets some high Input...
    I have tried a lot of tricks, but it don't solve my problem (counting the impulses on the input takes to much of codespace, using a FOR-NET-Loop instead isn't better...)
    The ISM-Connecting works fine (10 Bytes $55 or so to sync and 1 Start-byte $96 and 4 Bytes ($A5 or so) to carry 8 bit of information ... I am a lousy pragmatiker)
    But the timeout in the SERIN (and more in the SERIN2) -Command makes me worry....
    At the weekend I begin to change the librarys of PBP !
    BTW: Accessing X[1] or so with the SERIN / SEROUT-command will not work, it seems to be fouly....
    Dec 2003
    Wichita KS
    Try tying your receiver pin to ground, to force a ground. thus hopefully getting rid of the "noise". your Serin is reacting to Noise. And you need to rid yourself of this noise.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Try to use the internal USART, you must use HSERIN instead of SERIN. If you want to be sure to not overflow the input buffer add
    DEFINE HSER_CLROERR 1
    at the begining of your program.
    For the noise... have you any pull down/Pull up resistor on the RX pin of your PIC. Do you use MAX232 ???
    "At the weekend I begin to change the librarys of PBP !"
    Must be sure that's the problem before...!!! I'm pretty curious to see your code and schematics before.
    Hangover, Germany
    Hello,
    the noise is coming out of the ISM-receiver, because of the free floating of the filters...
    It can't be turned off with a resistor!
    Because our local dealer has no PICs, I must look at the sources in the librarys.... Uuups.
    Hangover, Germany
    Default Fixed!
    I has managed the problem....
    Throw away these timeout-feature of the PBP!
    Use handcoded programs !
    Using Timer1 as a Timer (475ms) and the stupid SERIN-Command to look into the stream of pulses out of the receivers...
    If there is a byte (and the SERIN will receive MANY! ... they ignore the stopbit and don't check the framing....) check it and if it is our startbyte, get the next 4 bytes.
    Putting this in a loop until the Timer is done...
    ;Timer1 setzen
    ;Teiler /8 OSC/4 als Input = 125kHz
    T1CON.5=1
    T1CON.4=1
    ;0,475 Sekunden = -59375 = 1811h
    TMR1H=$18
    TMR1L=$11
    ;INT-Flag löschen
    PIR1.0=0
    ;GO!
    T1CON.0=1
    ;Flag für Müll-Empfang setzen
    Dummy_Bit=1
    ;Funkmodul auslesen
    REPEAT
    SERIN Funk_IN,T2400,Dummy
    IF Dummy=$96 THEN
    SERIN Funk_IN,T2400,Buf_Sin[0],Buf_Sin[1],Buf_Sin[2],Buf_Sin[3]
    ;merken, daß ein Empfang stattfand
    Dummy_Bit=0
    ;Zeit ablaufen lassen
    UNTIL PIR1.0
    ;Timer stoppen
    T1CON.0=0
    ;empfangene Zeichen auf Byte umrechnen
    Dummy=Buf_Sin[0]:GOSUB Manch2Bit
    Dummy=Buf_Sin[1]:GOSUB Manch2Bit
    Dummy=Buf_Sin[2]:GOSUB Manch2Bit
    Dummy=Buf_Sin[3]:GOSUB Manch2Bit
  1. Serin timeout not working properly!
    Last Post: - 1st January 2010, 21:56
  2. SERIN timeout
    By Del Tapparo in forum Serial
    Last Post: - 20th November 2007, 05:34
  3. SERIN Timeout
    By George in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 16:06
  4. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  5. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
