Pin 13 I\o
Results 1 to 2 of 2
Thread: Pin 13 I\o
    ron6699's Avatar
    ron6699 Guest
    Question Pin 13 I\o
    Hello!
    Can You help me?
    i want to write 16byte in internel eeprom,
    then read the 16 byte an send it on pin 13 out.
    My programm:
    SO CON 0
    N2400 CON 4
    B0 = VAR BYTE
    B1 = VAR BYTE
    B1 = "X"
    A = VAR BYTE
    OUTPUT 13
    HIGH 4
    FOR A=0 TO 15
    WRITE A,B1
    NEXT A
    FOR A=0 TO 15
    READ A,BO
    SEROUT SO,N2400,[#B0," "]
    NEXT A
    I will programm it on a goldcard and put it in a chipdrive!
    Why doesnt it works?
    Thank's
    RON
    Hi Ron,
    A few things going on here.
    You've set SO as a constant of 0, then later used SO as the SEROUT pin. That will put the Serial Output on PORTB.0. I'm not sure which PIC you're using, but it's probably not pin 13.
    Variable declarations...
    B0 = VAR BYTE
    B1 = VAR BYTE
    should not have equal signs in them.
    B0 VAR BYTE
    B1 VAR BYTE
    I'm not sure what these two lines are for...
    OUTPUT 13
    HIGH 4
    but they have no bearing on your program.
    Try it like this
    SO    VAR  PORTB.0   ' Or whichever pin you like
    N2400 CON 4
    B0    VAR  BYTE
    B1    VAR  BYTE
    A     VAR  BYTE
    B1 = "X"
    FOR A=0 TO 15
        WRITE A,B1
    NEXT A
    FOR A=0 TO 15
        READ A,BO
    NEXT A
    HTH,
        Darrel
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  3. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. Pin High for 13 seconds while....
    Last Post: - 16th June 2005, 01:36
