Hi, Atom
Those lines Have Passed the MPSIM Test ...
@ DEVICE pic12F629, INTRC_OSC_NOCLKOUT ; Using Internal Clock, no clock out
@ DEVICE pic12F629, WDT_ON ; Enable Watch dog timer
@ DEVICE pic12F629, PWRT_ON ; Enable Power-up timer
@ DEVICE pic12F629, MCLR_OFF ; Disable MCLR pin
@ DEVICE pic12F629, BOD_ON ; Enable Brown-out detect
@ DEVICE pic12F629, CPD_OFF ; EEPROM Protect
@ DEVICE pic12F629, PROTECT_OFF ; Code Protect off
'@ __CONFIG _INTRC_OSC_NOCLKOUT &  _WDT_ON & _PWRTE_ON & _BODEN_ON & _MCLRE_OFF
DEFINE OSCCAL_1K 1
DEFINE BUTTON_PAUSE 20
GPIO	= %00000000
TRISIO 	= %11111110
INTCON.6=0 ' Disable all unmasked Interrupts
INTCON.7=0 ' Disable Global Interrupts
CMCON = 7 ' Disable analog comparator
ServoOut 	var GPIO.0
SetLimitSw 	var GPIO.1
PotIn 		var GPIO.2
MinSw 		var GPIO.4
MaxSw 		var GPIO.5
Delay		var Byte
Posit 		var Byte
MinPosit 	var Byte
MaxPosit 	var Byte
'load starting min and max positions at program time
data @ 0,100
data @ 2,250
low Servoout
'read in stored min and max limits
read 0, MinPosit
read 2, MaxPosit
Start:
gosub GetServoPosition
Low 	servoout
pulsout servoout, posit
Delay = 0
BUTTON setlimitsw, 0, 255, 0, Delay, 1, Start
	Delay = 0
	BUTTON minsw, 1, 255, 0, Delay, 1, MinL		'20 ms
	Delay = 0
	BUTTON maxsw, 1, 255, 0, Delay, 1, MaxL		' 20 ms
	pause 20					' no button pushed
	Goto Start
MinL:
	IF maxsw = 1 THEN Start		'1 Button pushed at a Time !!!
	IF Posit <> MinPosit THEN
		MinPosit = Posit
		write 0, MinPosit						'10 ms
goto start
MaxL:
	IF minsw = 1 THEN Start		'1 Button pushed at a Time !!!
	IF Posit <> Maxposit THEN
		MaxPosit = Posit
		write 2, MaxPosit						' 10 ms
goto start
GetServoPosition:
high potin
pause 1
rctime potin, 1, Posit 'at 4 mhz, returns 3 - 123 :: 1.23 ms max
'adjust posit to get values between 75 and 250
posit = posit + 75 + (posit / 2)
'now limit posit to 100 - 250 (1 ms - 2.5 ms)
if posit < 100 then posit = 100
if posit > 250 then posit = 250
if setlimitsw = 0 then 'apply limits
	if Posit < MinPosit then Posit = MinPosit
	if Posit > MaxPosit then Posit = MaxPosit
 Try those lines ... should work !!!
