Problem with 12F629, servo and EEPROM
Results 1 to 14 of 14
    Sep 2006
    Florida, USA
    Default Problem Solved!
    Well, just as I expected, it was me and yes, I'm embarassed! I started metering the min and max buttons and noticed that if I pressed either button, both pins went high - explaining why the servo just stayed in one spot when either the min or max button was pressed. After scratching my head over how that could possibly be happening, I noticed that my pull-down resistors were put in vertically instead of horizontally. If you look at the circuit diagram in my first post, you will see what I mean. How stupid was that! Anyway, I rotated the resistors and everything works perfectly! Go figure!
    I'd like to thank those who helped me and apologize for wasting their time. I knew it would be something like this...
    Well, I made a few changes to the code and here it is in it's final form:
    @ DEVICE pic12F629, INTRC_OSC_NOCLKOUT ; Using Internal Clock, no clock out
    @ DEVICE pic12F629, WDT_ON ; Enable Watch dog timer
    @ DEVICE pic12F629, PWRT_ON ; Enable Power-up timer
    @ DEVICE pic12F629, MCLR_OFF ; Disable MCLR pin
    @ DEVICE pic12F629, BOD_ON ; Enable Brown-out detect
    @ DEVICE pic12F629, CPD_OFF ; EEPROM Protect
    @ DEVICE pic12F629, PROTECT_OFF ; Code Protect off
    TRISIO = %11111110
    INTCON.6=0 ' Disable all unmasked Interrupts
    INTCON.7=0 ' Disable Global Interrupts
    CMCON = 7 ' Disable analog comparator
    ServoOut var GPIO.0
    SetLimitSw var GPIO.1
    PotIn var GPIO.2
    MinSw var GPIO.4
    MaxSw var GPIO.5
    wPosit var word
    Posit var byte
    MinPosit var byte
    MaxPosit var byte
    'load starting min and max positions
    data @ 0, 100
    data @ 1, 250
    low Servoout
    'read in stored min and max limits
    read 0, MinPosit
    read 1, MaxPosit
    'for power-on reset of positions:
    if minsw = 1 then
    minposit = 100
    write 0, minposit
    if maxsw = 1 then
    maxposit = 250
    write 1, maxposit
    Start:
    gosub GetServoPosition
    pulsout servoout, posit
    pause 20
    if setlimitsw = 1 then 'check min max buttons
    if minsw = 1 then
    MinPosit = Posit
    write 0, MinPosit
    pause 250
    if maxsw = 1 then
    MaxPosit = Posit
    write 1, MaxPosit
    pause 250
    goto start
    GetServoPosition:
    high potin
    pause 1
    rctime potin, 1, wPosit 'at 4 mhz, returns 0 - 120
    'adjust posit to get values between 75 and 250
    'use word-sized variable because calculation might exceed 255
    wposit = wposit + 75 + (wposit / 2)
    'now limit posit to 100 - 250 (1 ms - 2.5 ms)
    'and put into byte-sized variable
    if wposit > 250 then
    posit = 250
    posit = wposit
    if posit < 100 then posit = 100
    if setlimitsw = 0 then 'apply limits
    if Posit < MinPosit then Posit = MinPosit
    if Posit > MaxPosit then Posit = MaxPosit
    Default Beware the PULSOUT inversion problem
    PULSOUT is a toggle. Sooner or later you will get some interference that flips the state of the SERVOOUT line and your system will be off in the weeds.
    To guarantee correct working of the PULSOUT command you should first force the SERVOOUT line to a defined state.
    For example, put
    SERVOOUT = 0
    or
    LOW SERVOOUT
    before calling the Pulsout command.
    One of my RC aircraft went berserk because of that little oversight.
    HTH
    Brian
    Quote Originally Posted by BrianT View Post
    HTH
    Brian
    You mean like pulling UP out of an inverted low pass?
    I lost a hopped-up clipped wing (+an extra bay) Goldberg Cub that way....(sigh)....
    Hi, BrianT
    To fullfill your Pulsout knowledge ...
    You are to use LOW Output ...
    with some Hot plugged servos ( Graupner i.e.) or High capacitive loads ( some µF ) , Output = 0 is not enough to have a neat O level prior to Pulsin.
    I know it's not supposed to happen in flight ... but, ...
    Service,Sir ...
  1. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  2. Writing to a table.
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 24th December 2005, 16:20
  3. Servo Recording
    By kenpo in forum General
    Last Post: - 2nd September 2005, 16:03
