Problem with 12F629, servo and EEPROM
Results 1 to 14 of 14
Threaded View
  1. #6
    Hi, Atom
    Those lines Have Passed the MPSIM Test ...
    @ DEVICE pic12F629, INTRC_OSC_NOCLKOUT ; Using Internal Clock, no clock out
    @ DEVICE pic12F629, WDT_ON ; Enable Watch dog timer
    @ DEVICE pic12F629, PWRT_ON ; Enable Power-up timer
    @ DEVICE pic12F629, MCLR_OFF ; Disable MCLR pin
    @ DEVICE pic12F629, BOD_ON ; Enable Brown-out detect
    @ DEVICE pic12F629, CPD_OFF ; EEPROM Protect
    @ DEVICE pic12F629, PROTECT_OFF ; Code Protect off
    '@ __CONFIG _INTRC_OSC_NOCLKOUT &  _WDT_ON & _PWRTE_ON & _BODEN_ON & _MCLRE_OFF
    DEFINE OSCCAL_1K 1
    DEFINE BUTTON_PAUSE 20
    GPIO	= %00000000
    TRISIO 	= %11111110
    INTCON.6=0 ' Disable all unmasked Interrupts
    INTCON.7=0 ' Disable Global Interrupts
    CMCON = 7 ' Disable analog comparator
    ServoOut 	var GPIO.0
    SetLimitSw 	var GPIO.1
    PotIn 		var GPIO.2
    MinSw 		var GPIO.4
    MaxSw 		var GPIO.5
    Delay		var Byte
    Posit 		var Byte
    MinPosit 	var Byte
    MaxPosit 	var Byte
    'load starting min and max positions at program time
    data @ 0,100
    data @ 2,250
    low Servoout
    'read in stored min and max limits
    read 0, MinPosit
    read 2, MaxPosit
    Start:
    gosub GetServoPosition
    Low 	servoout
    pulsout servoout, posit
    Delay = 0
    BUTTON setlimitsw, 0, 255, 0, Delay, 1, Start
    	Delay = 0
    	BUTTON minsw, 1, 255, 0, Delay, 1, MinL		'20 ms
    	Delay = 0
    	BUTTON maxsw, 1, 255, 0, Delay, 1, MaxL		' 20 ms
    	pause 20					' no button pushed
    	Goto Start
    MinL:
    	IF maxsw = 1 THEN Start		'1 Button pushed at a Time !!!
    	IF Posit <> MinPosit THEN
    		MinPosit = Posit
    		write 0, MinPosit						'10 ms
    goto start
    MaxL:
    	IF minsw = 1 THEN Start		'1 Button pushed at a Time !!!
    	IF Posit <> Maxposit THEN
    		MaxPosit = Posit
    		write 2, MaxPosit						' 10 ms
    goto start
    GetServoPosition:
    high potin
    pause 1
    rctime potin, 1, Posit 'at 4 mhz, returns 3 - 123 :: 1.23 ms max
    'adjust posit to get values between 75 and 250
    posit = posit + 75 + (posit / 2)
    'now limit posit to 100 - 250 (1 ms - 2.5 ms)
    if posit < 100 then posit = 100
    if posit > 250 then posit = 250
    if setlimitsw = 0 then 'apply limits
    	if Posit < MinPosit then Posit = MinPosit
    	if Posit > MaxPosit then Posit = MaxPosit
    Try those lines ... should work !!!
  1. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  2. Writing to a table.
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 24th December 2005, 17:20
  3. Servo Recording
    By kenpo in forum General
    Last Post: - 2nd September 2005, 17:03
