18F4550 Solar battery charger / regulator & inverter system
Results 1 to 15 of 15
    Jan 2006
    Istanbul
    RYTECH,
    Do you need the solar panels ONLY for charging?
    I did not get it clear enough with the posts above.
    Jul 2005
    Hi people... sorry for the delayed response, i've gotten somewhat sidetracked designing a perpetual motion machine...lol...
    as for the power system.. I would like it to a) recharge the batteries and b) supply the load with any additional unused power from various input sources...
    Feb 2011
    Default Re: 18F4550 Solar battery charger / regulator & inverter system
    NEWARK and MOUSER sell the PB137 it is a 13.7V version of the 7815.
    13.7V is the perfect voltage for Sealed Batteries, you NEVER EVER WANT TO OVER CHARGE THEM 14.1V is the absolute max.
    GEL CELLS will never heal from overcharging, the bubbles form and push the mat away from the plate, the bubbles do not dissolve or move.
    I like your idea, you could measure the amount of current flowing IN to the batteries if they are not receiving then you can by pass shunt off the excess.
    On ebay many folks are sellling dc-dc converters, you can use these to stabilize the power from the panels
  1. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 19:15
  2. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 00:28
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 08:25
  4. calibration clock 12f508
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 10:33
  5. 12v Lead acid solar charger
    Last Post: - 26th May 2006, 22:01
