18F4550 Solar battery charger / regulator & inverter system
Results 1 to 15 of 15
Threaded View
    Jul 2005
    Question 18F4550 Solar battery charger / regulator & inverter system
    I was wondering if anyone could comment on why I should or should not build this (see attached diagram)... it's a step up (or perhaps down) from how I've used my solar array and existing battery bank in the past, which was basically just feeding power directly from my solar array (currently about 33w) into my battery bank (was using 8xparallel 12v 2ah SLA) and connecting my inverters/regulators off that positive rail no current or voltage regulation. The solar array was connected previously via a over-voltage cutoff device which read the voltage level of the batteries. The relay which connects the solar cells to the battery bank is intended to perform a similar duty in this (currently theoretical) circuit.
    I did some work last summer experimenting with the max4172 ic's which appear to offer reliable readings as to how much current is flowing between given points in a circuit.
    Any suggestions on how to improve this circuit without adding a lot of complexity?
    Any comments regarding the use of diode's in the circuit to direct traffic? The intent was to prevent power from coming into the batteries aside from what is flowing through the voltage / current regulated source while still providing any additional power coming in from the solar array directly to the regulators which provide power to the connected loads.
  1. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 19:15
  2. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 00:28
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 08:25
  4. calibration clock 12f508
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 10:33
  5. 12v Lead acid solar charger
    Last Post: - 26th May 2006, 22:01
