Getting the "," in the middle
Results 1 to 6 of 6
    Talking Getting the "," in the middle
    Hi all,
    i'm trying to separate a value with a "," .
    I have a sensor input value that is stored with 3 digits (xxx) into the eeprom but when exporting using the debug command i need to have the xx,x format.
    In the manual i found the DIG command but i'm not getting it to work together with the debug command.
    The DEC2 works with the debug command but this is not the right choice for this i think.
    debug dec2 VA,",",dec1 VA,13,10
    how can i do it with the debug command ?
    Jul 2005
    Midwest
    untested and not thought out
    debug dec2 VA/10,",",dec1 VA//10,13,10
    Quote Originally Posted by Steve_88 View Post
    The above post works fine...
    Here's another version of the same thing, again, documented in the PBP manual...
    va = 54321
    debug (va dig 5), "," , (va dig 4) , "," , (va dig 3) , "," , (va dig 2) , "," , (va dig 1) , "," , (va dig 0) ,13 , 10
    output would be
    5,4,3,2,1
    I'm sure you could modify the above to get what you want.
    Thanks Steve_88,skimask
    about the DIG command i wasn't using the () ... that's why it didn't worked
    cheers
    Hi all,
    i recently descovered a little bug in my code.
    The result value was working just fine and i was getting it in the xx,x format.
    This works well until i reach 99,9șC. After this i get the 4th digit in and the result ( instead of 110,5șC for example ) is 10,5șC .
    This is due to the way the code is handling the value and sending it out.
    'code for AD
    adcin temp,va
    tempe=(va*/2500 )>>2
    'code to output value retrieved from eeprom
    debug dec2 RA/10,",",dec1 RA//10,13,10
    How can i get the "," in there with 3 digits but keeping it when it reaches the 4th ?
    EDIT:
    This is what i i'm thinking:
    debug dec3 RA/10,",",dec1 RA//10,13,10
    Any idea ?
    Wink
    Hello rujic
    Last edited by Acetronics2; - 30th March 2008 at 16:06. Reason: have to read before answering !!!
  1. RB0 + Internal Pullup + Interrupt
    By Freman in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 12:11
  2. pins in arrays?
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 17th September 2005, 09:18
  3. pic with 3.3v
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 8th July 2005, 19:28
