How long distance for RS232 ?
Results 1 to 8 of 8
    Default How long distance for RS232 ?
    Hi all
    I use MAX232 or DS275 with PIC16f877A to make serial communication, anyone know how long distance for this communication ??
    Oct 2003
    holland
    For rs 232c communication is 1200 m max.
    If you change it to rs422 or rs485 then a few Km more is no problem.
    Quote Originally Posted by mat janssen View Post
    In real life with RS232 you can expect around 100 feet (30 meters).
    I am talking a reliable setup with good shielded cable and the environment used in does not have great amount of noise (electrical).
    Sep 2005
    Campbell, CA
    It depends a lot on the cable and the baud rate. Many years ago, I ran 115Kbaud through 100' and 19.2Kbaud through 300' of expensive shielded cable. It was for PC network that ran through serial ports instead of Ethernet.
    Charles Linquist
    Thanks for your replies
    I think that RS485 will be a good choice for long distance as I read in some sites
    What is your definition for long?
  1. Questions on ultrasonic distance finder
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 20th April 2010, 21:19
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  3. Long distance Communicating between PICs
    Last Post: - 4th January 2008, 06:47
  4. Long varible strings
    By flashg in forum Serial
    Last Post: - 14th October 2006, 04:40
  5. Long Distance Input's to Pic
    By GregK in forum General
    Last Post: - 21st April 2005, 09:37
