new to 8 pin pic
Results 1 to 15 of 15
    P.S. The 12F629 is not a 12-bit core device. It's 14-bit, so pretty much any PBP command should work just fine with it. As long as it's not a hardware command for a peripheral that doesn't exist on the PIC itself.
    Jeeze...I don't know how many times I've done that to myself! I've done bunches of applications with the 12Fxxx and it seems like every time, I talk myself into the fact it's a 12-bit...only to RE-figure out after a few days that it's actually a 14.
    (Ok...I'll take a burger and one FOREHEAD SLAP to go...)
    Some of the 12Fxxx series are 12-bit core. Just not this one. In general, 12F5xx are
    12-bit core, and 12F6xx are 14-bit core. The Program Memory Organization section of most
    data sheets will normally indicate the core type, so it's worth a quick check if you're not
    sure.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. newbe looking for PIC advice
    By Mad Professor in forum General
    Last Post: - 27th May 2009, 07:56
  3. PIC to PIC communication problem
    Last Post: - 21st June 2007, 03:51
  5. 8 port Signal Loss Detector, possible to use a pic?
    Last Post: - 20th March 2006, 15:59
