new to 8 pin pic
Results 1 to 15 of 15
    Sep 2005
    thanks skimask,
    i did not realize that there was specific info on the 8 pin pic in the manual.
    that should be a great help.
    thanks again,
    mike
    Hi Mike,
    Welcome to the forum. This series PIC has a 4MHz internal oscillator, an analog comparator,
    and a host of other goodies you'll need the data sheet to get familiar with.
    CMCON = 7 will disable the onboard comparator so you can use associated pins as digital I/O.
    If you plan to use the internal oscillator, then you'll want to enable it using the INTRC_OSC
    option in config. Use this below to get started. Just place the next line at the very beginning
    of your program.
    @ DEVICE pic12F629, INTRC_OSC_NOCLKOUT,WDT_OFF,PWRT_ON,MCLR_OFF,BOD_ON,CPD_OFF,PROTECT_OFF
    DEFINE OSCCAL_1K 1' Set OSCCAL for 1k ' <-- this loads the factory calibration value for the int osc
    DEFINE OSCCAL_1K 1 is in your PBP manual.
    If you're curious about what all these config options are, just look in the data sheet under
    the Special Features of the CPU section. You might also want to use the search feature
    here to turn up even more info, but this will get you up & going for now.
    I/O-pins on these are refered to as GPIO. GPIO.0, GPIO.1, etc,,.
    The TRIS register is called TRISIO. TRISIO = %xxx x being 1's or 0's for inputs or outputs.
    Now try something simple just to get familiar with the 12F part;
    DEFINE OSCCAL_1K 1
        CMCON = 7
    loop:
        High GPIO.0 ' Turn on LED connected to 0
        Pause 500 ' Delay for .5 seconds
        Low GPIO.0 ' Turn off LED connected to 0
        GoTo loop ' Go back to loop and blink LED forever
    TIP: Just in case, you might want to first read a new 12F629 with your device programmer,
    and jot down the factory calibration value. If your programmer erases this, you'll need to
    know what it was.
    There should be several threads around here with info on finding the proper value again, so
    I won't re-type it all again here.
    Use the search feature here to look around for more on using the 12F series. If you have
    more questions after reading any of them, then fire away.
    MeLabs has a few examples for the LAB-X4 board you might also want to have a look at;
    http://www.microengineeringlabs.com/doclist.htm#X4
    P.S. The 12F629 is not a 12-bit core device. It's 14-bit, so pretty much any PBP command
    should work just fine with it. As long as it's not a hardware command for a peripheral that
    doesn't exist on the PIC itself.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    thanks bruce,
    that is the exact information i was looking for.
    now it's time to experiment with it.
    i have learned a lot over the years from your website. keep up the good work!
    thanks again,
    mike
    P.S. The 12F629 is not a 12-bit core device. It's 14-bit, so pretty much any PBP command should work just fine with it. As long as it's not a hardware command for a peripheral that doesn't exist on the PIC itself.
    Jeeze...I don't know how many times I've done that to myself! I've done bunches of applications with the 12Fxxx and it seems like every time, I talk myself into the fact it's a 12-bit...only to RE-figure out after a few days that it's actually a 14.
    (Ok...I'll take a burger and one FOREHEAD SLAP to go...)
    Some of the 12Fxxx series are 12-bit core. Just not this one. In general, 12F5xx are
    12-bit core, and 12F6xx are 14-bit core. The Program Memory Organization section of most
    data sheets will normally indicate the core type, so it's worth a quick check if you're not
    sure.
    -Bruce
    tech at rentron.com
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. newbe looking for PIC advice
    By Mad Professor in forum General
    Last Post: - 27th May 2009, 07:56
  3. PIC to PIC communication problem
    Last Post: - 21st June 2007, 03:51
  5. 8 port Signal Loss Detector, possible to use a pic?
    Last Post: - 20th March 2006, 15:59
