How long a variable has the same value?
Results 1 to 3 of 3
    Jan 2006
    Istanbul
    Have a look at this;
    Modify as desired.
    <font color="#000000">Value <font color="#000080"><b>VAR BYTE
    </b></font>T1CON  = <font color="#FF0000"><b>%00110100  </b></font><font color="#000080"><i>'TMR1GE enabled, Prescaller 1:8, LP OFF, No Sync, Internal Clk
    </i></font>TMR1IF    <font color="#000080"><b>VAR </b></font>PIR1.<font color="#FF0000"><b>0  </b></font><font color="#000080"><i>'Timer1 Overflow bit.
    </i></font>TMR1ON    <font color="#000080"><b>VAR </b></font>T1CON.<font color="#FF0000"><b>0 </b></font><font color="#000080"><i>'Timer1 Start/Stop bit.
    </i></font>Pulsepin  <font color="#000080"><b>VAR </b></font>GPIO.<font color="#FF0000"><b>0
    </b></font>Limit     <font color="#000080"><b>CON </b></font><font color="#FF0000"><b>150 </b></font><font color="#000080"><i>' Desired Pulse limit.
    </i></font>TimeDone   <font color="#000080"><b>CON </b></font><font color="#FF0000"><b>6   </b></font><font color="#000080"><i>' Desired Time. Each unit is 524mS. 6 = approx. 3 secs.
    </i></font>CountTime <font color="#000080"><b>VAR BYTE
    </b></font>Loop:
        TMR1L  = <font color="#FF0000"><b>0
        </b></font>TMR1H  = <font color="#FF0000"><b>0
        </b></font>TMR1IF = <font color="#FF0000"><b>0
        </b></font>TMR1ON = <font color="#FF0000"><b>0
        </b></font><font color="#000080"><b>PULSIN </b></font>Pulsepin, <font color="#FF0000"><b>1</b></font>, Value
        <font color="#000080"><b>IF </b></font>Pulsepin &gt; Limit <font color="#000080"><b>THEN </b><i>' Incoming pulse is greater then desired pulse limit.
           </i></font>TMR1ON = <font color="#FF0000"><b>1            </b></font><font color="#000080"><i>' Start Timer.
           </i></font>CountTime = <font color="#FF0000"><b>0         </b></font><font color="#000080"><i>' Clear time variable.
           </i><b>WHILE </b></font>Pulsepin &gt; Limit <font color="#000080"><i>'Loop while the incoming pulse is greater then limit.
             </i><b>PULSIN </b></font>Pulsepin, <font color="#FF0000"><b>1</b></font>, Value
             <font color="#000080"><b>WHILE </b></font>TMR1IF = <font color="#FF0000"><b>0                 </b></font><font color="#000080"><i>' Wait about 524ms.
                </i><b>PULSIN </b></font>Pulsepin, <font color="#FF0000"><b>1</b></font>, Value     <font color="#000080"><i>' Keep reading.
                </i><b>IF </b></font>Pulsepin =&lt; Limit <font color="#000080"><b>THEN </b></font>Jump <font color="#000080"><i>' In case Pulse changed then exit!
             </i><b>WEND
             </b></font>TMR1IF = <font color="#FF0000"><b>0                           </b></font><font color="#000080"><i>'Clear timer1 overflow bit.
             </i></font>CountTime = CountTime + <font color="#FF0000"><b>1            </b></font><font color="#000080"><i>' Count Timer1 ticks,
             </i><b>IF </b></font>CountTime = TimeDone <font color="#000080"><b>THEN </b></font>Dothings <font color="#000080"><i>' ...Exit loop if time is out.
                                                      'and do your stuff.
           </i></font>Jump:
           <font color="#000080"><b>WEND
    GOTO </b></font>Loop
    Dothings:
    <font color="#000080"><i>' do somethings here.
    </i><b>GOTO </b></font>Dothings
    Great!!! Thanks a lot!!!
    I'll read it and test it this weekend.
    Daniel.
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. signed long (32-bit) variable
    By Stephan in forum mel PIC BASIC Pro
    Last Post: - 11th September 2007, 04:40
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Long varible strings
    By flashg in forum Serial
    Last Post: - 14th October 2006, 05:40
