Timer problem
Results 1 to 3 of 3
Thread: Timer problem
    Perth, Australia
    Default Timer problem
    I'm having a problem with the timers on the 18F4550. I wrote the below code to test the timer, but im getting unexpected results:
    Define OSC 48
    DEFINE LCD_DREG      PORTD
    DEFINE LCD_DBIT      4
    DEFINE LCD_RSREG     PORTC
    DEFINE LCD_RSBIT     1
    DEFINE LCD_EREG      PORTC
    DEFINE LCD_EBIT      2
    DEFINE LCD_BITS      4
    DEFINE LCD_LINES     2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS    50
    temp var byte
    ' Timer 0: 8-Bit, 1:256 prescaler, 128uS/tick
    T0CON=%11010111
    TMR0L=0
    pauseus 2048
    temp=TMR0L
    lcdout $FE,1,$FE,2,#temp
    loop: goto loop
    At 128uS per tick of the timer, i'd expect a result of about 8, however I get 95.
    I have a 4Mhz crystal, and heres my config:
            __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Kamikaze47 View Post
    At 48Mhz...
    Each MCU instruction cycle = .083us ( 1/ (48mhz/4) )
    .083us * 256 for the Timer 0 prescaler = 21.3us
    2048 us pause / 21.3 us per T0 tick = 96
    Perth, Australia
    *slaps forehead*
    I'm not sure how I ended up with 128uS/tick... I must have worked it out on a 8Mhz clock instead of 48Mhz.
    thanks skimask
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  3. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  4. Interesting delay problem
    By Kreston in forum mel PIC BASIC Pro
    Last Post: - 1st September 2008, 15:41
  5. Timer problem
    By Tastature in forum mel PIC BASIC Pro
    Last Post: - 31st July 2008, 20:38
