Reading code ROM
Results 1 to 8 of 8
    Sep 2005
    Campbell, CA
    READCODE works.
    If your chip is larger than 64K bytes, and you are using any version of PBP before 2.50, you will either have to modify your libraries or use an ASM routine to read the memory above 655535.
    If you are using PBP 2.50 (and PBPL) you can read the whole chip using READCODE even if it is a > 64K device.
    Charles Linquist
    Nov 2007
    Thanks Charles. I got the book out and found the READCODE command. I've never used that one and had missed it when I was looking through the book yesterday. Now I need to figure out how to produce a CRC value for the code space. Thanks again.
    Sep 2005
    Campbell, CA
    There are several CRC16 examples on the forum. One of them should be usable for your application. For verifying code, I usually do just a checksum - sum all the bytes into one 16 bit word. It is fast and is usually good enough.
    Charles Linquist
    Quote Originally Posted by markk5xh View Post
    Are you trying to read your own code and produce your own CRC or what?
    Nov 2007
    Yes, my code.
    I'm looking at a project that requires the software/firmware to meet a U.L. spec. One of the requirements is that the program code must be verified in some way. What the spec calls for is either a "single word" CRC or a "double word" CRC. Their use of the word "word" is a bit confusing as they seems to mean 8 bits and not 16. After reading through the spec (300+ pages) I'm not even sure that a PIC can be used in such a project.
    Thanks for your input.
    Mark
    Yes, my code.
    Mark
    Simple idea, , yet probably not so practical...???
    Read your own PIC code, and compare it word for word against an external EEPROM burned with the same code...
    Nov 2007
    Actually this is one of the methods that is discribed in the UL documents. I agree that it might not be the best way. Thanks for the input.
  1. Problem runing my code
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 20:36
  2. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 19:48
  3. 16F to 18F transition pains
    By lurker in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 01:35
  4. Code to control 4 LEDs and 2 servos
    Last Post: - 26th November 2008, 13:33
  5. one wire
    By karenhornby in forum General
    Last Post: - 18th June 2008, 20:24
