Zk_bamx2,
you need winXP, .net &MPLAB8 and its associated package pblished on MIcrochip.com
You have to install the pickit2 2.4 driver .
After plugging in the PICKIT2, run the pickit2 software-- select midrange devices, select 16f84A and then load the HEX file.
make a small cable to plug into the ICSP socket - pins are described by them
connect the other end to the relevant pins of the f84A..
It should be possible to program Sir.
