Hi all,
i've sucessfuly made some programs already but i'm still in a very rookie position.
I'm working on a program ( pic 16F88 ) to read temp and save it into an external eeprom.
Here's the code and at the end the questions
SSPCON.5 = 0                ; Disable SSP Module
TXSTA.5 = 0                 ; Disable AUSART Tx
RCSTA.7 = 0                 ; Disable Serial Port
OSCCON          = %01111110 'Internal RC w/ I/Os
INTCON=0
PIE1     = 0
'PIE2    = 0
PIR1                 = 0                   'off
CMCON= 7
CVRCON= 0                   'Vref Off
CCP1CON= 0
T1CON= 0
'T2CON = %00000100
'DEFINEs
@ DEVICE INTRC_OSC
@ DEVICE MCLR_OFF
@ DEVICE PROTECT_OFF
DEFINE osc 4
@ DEVICE CPD_OFF
@ DEVICE LVP_OFF
@ DEVICE BOD_OFF
@ DEVICE PWRT_OFF
@ DEVICE WDT_OFF
'ADC
DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
'ADC parameters
ADCON1  =%10000000      'right justify
ANSEL   =%00000101
ADCON0  =%11000001
INCLUDE "modedefs.bas"
'settings for serial comm
DEFINE debug_reg PORTA
DEFINE debug_bit 1
DEFINE debug_baud 9600
DEFINE debug_mode 1
'I/O's
PORTA=0
PORTB=0
TRISA=%00100101
TRISB=%00000011
'PINS
temp    var PORTA.0
out     var PORTA.1
volt    var PORTA.2
a3      var PORTA.3
A4      var PORTA.4
but1    var PORTA.5
led2    var PORTA.6
led1    var PORTA.7
but2    var PORTB.0
but3    var PORTB.1
SCL     var PORTB.2
SDA     var PORTB.3
green    var PORTB.4
red       var PORTB.5
led4      var PORTB.6
led3      var PORTB.7
' variables
va       var word
va2      var word
tempe    var word
volte    var word
mem      var byte
p1a      var word
p1b      var word
p2a      var word
p2b      var word
p3a      var word
p3b      var word
p4a      var word
p4b      var word
state   var byte
st      var word
ed      var word
ADDR    var word
m1      var  byte
m2      var byte
m3      var byte
m4      var byte
slot    var bit
w       var byte
CTW     VAR BYTE
km      var byte
ra      var word
set1    VAR BYTE
set2    VAR BYTE
rm      var byte
x       var byte
CLEAR
mem=1
state=1
p1a=$10
p1b=$1070
p2a=$1080
p2b=$2140
p3a=$2160
p3b=$3220
p4a=$3230
p4b=$4290
start:
high out
debug $0D, $0A
PAUSE 50
CTW=$A0
debug "start menu",13,10
startmenu:
I2CREAD SDA,SCL,CTW,1,[m1]
I2CREAD SDA,SCL,CTW,2,[m2]
I2CREAD SDA,SCL,CTW,3,[m3]
I2CREAD SDA,SCL,CTW,4,[m4]
if (mem=1) and (m1=0) then
led1=1
led2=0
led3=0
led4=0
slot=0
if (mem=1) and (m1<>0) then
pause 300
toggle led1
led2=0
led3=0
led4=0
slot=1
if (mem=2) and (m2=0) then
led1=0
led2=1
led3=0
led4=0
slot=0
if (mem=2) and (m2<>0) then
led1=0
pause 300
toggle led2
led3=0
led4=0
slot=1
if (mem=3) and (m3=0) then
led1=0
led2=0
led3=1
led4=0
slot=0
if (mem=3) and (m3<>0) then
led1=0
pause 300
led2=0
toggle led3
led4=0
slot=1
if (mem=4) and (m4=0) then
led1=0
led2=0
led3=0
led4=1
slot=0
if (mem=4) and (m4<>0) then
led1=0
pause 300
led2=0
led3=0
toggle led4
slot=1
if state=1 then
green=0
red=1
if state=2 then
green=1
red=0
if state=3 then
green=1
red=1
if (but1=1) and (state=1) then
gosub readmenu
if (but1=1) and (state=2) then
gosub recordmenu
if (but1=1) and (state=3) then
gosub erasemenu
if but3=1 then
gosub memorymenu
if but2=1 then
gosub statemenu
goto startmenu
recordmenu:
debug "Record Menu",13,10
if slot=1 then
goto warningmenu
if mem=1 then
st=p1a
ed=p1b
if mem=2 then
st=p2a
ed=p2b
if mem=3 then
st=p3a
ed=p3b
if mem=4 then
st=p4a
ed=p4b
recordmem:
debug "2s pause before start recording",13,10
PAUSE 2000
        FOR ADDR= st TO ed
 	for w = 0 to 15
        ADCIN temp, va
        va2=va + (temp>>4)
        NEXT
va = (va2 */ 5000 ) >> 2
va=va/10
        toggle red
        pause  824
        debug " Saved value:  ", dec va2," - ", dec va," In position  ", dec ADDR, 13,10
        debug " VA2 = ", dec va2,13,10
        I2CWRITE SDA,SCL,CTW,ADDR,[VA.highbyte]
        pause 10
        ADDR=ADDR+1
        I2CWRITE SDA,SCL,CTW,ADDR,[VA.lowbyte]
        pause 10
        ADDR=ADDR+1
        I2CWRITE SDA,SCL,CTW,mem,[addr]
        if but1=1 then      'stop recording
        pause 600
        goto startmenu
        toggle led1
        toggle led4
        NEXT
        red=1
erasemenu:
eraseblock:
debug "erasing block",dec mem,13,10
red=0
I2Cread SDA,SCL,CTW,mem,[x]
debug "before in position ",dec mem," - ",dec x,13,10
I2CWRITE SDA,SCL,CTW,mem,[0]
red=1
memorymenu:
if mem < 4 then
mem=mem+1
mem=1
debug DEC mem,13,10
pause 300
statemenu:
if state < 3 then
state=state+1
state=1
debug "state change - ", DEC state,13,10
pause 300
The code is mostly working but i have encountered some issues.
One of them is the eeprom ( 24LC512 ). I cant access ( read or write ) into it.
I have sucessfuly worked with this eeprom with a PIC12F675 but not with this 16F88
Other issue is reading the temp sensor. If i connect the sensor into PORTa.1 i get no decent readings ( just 1 and 0 ).
But if i change ADCON0, Ansel and Trisa to porta.0 it works.
I'm guessing this is due to some bad configuration i dont know were.
This is why i'm asking you pros to help me and take some questions away.
questions:
1.How do i turn the comparator off ?
I'm guessing that CCP1CON will turn it off.
If this is right, do i still need to add CMCON ?
2. I'm using the internal osc ( with MCLR off ). The OSCCON option should be "10 = Internal RC is used for system clock".
what does the other mean ?
00 = Oscillator mode defined by FOSC<2:0>
01 = T1OSC is used for system clock
3. For AD i have seen 2 diferent ways of programing:
One where we use a line to start the conversion, a line to capture the value and another to stop the conversion.
I always used the ADCin portx,a mode to do the job.
So, for ADCON0, my way i shoud use :
"bit 0 ADON: A/D On bit - 1 = A/D converter module is operating"
and "bit 2 GO/DONE: A/D Conversion Status bit - 1 = A/D conversion in progress (setting this bit starts the A/D conversion)"
Am i right ?
For the next bits :
000 = Channel 0 (RA0/AN0)
001 = Channel 1 (RA1/AN1)
010 = Channel 2 (RA2/AN2)
011 = Channel 3 (RA3/AN3)
100 = Channel 4 (RA4/AN4)
101 = Channel 5 (RB6/AN5)
110 = Channel 6 (RB7/AN6)
this means i can only choose one channel for ADC ? What if i need 2 input channels ?
Finally the last bits:
Since i'm using the internal OSC which one should i use and why ?
bit 7-6 ADCS<1:0>: A/D Conversion Clock Select bits
If ADSC2 = 0:
00 = FOSC/2
01 = FOSC/8
10 = FOSC/32
11 = FRC (clock derived from the internal A/D module RC oscillator)
If ADSC2 = 1:
00 = FOSC/4
01 = FOSC/16
10 = FOSC/64
Sorry for the long post and many questions
