MPASM Help
Results 1 to 8 of 8
Thread: MPASM Help
    Thanks, this helped a lot.
    The offending code, which works fine is.....
    LRC = 256 - LRC
    LRC is defined as a byte, but I have to subtract LRC from $100
    I guess I could say....
    LRC = $FF - LRC
    LRC = LRC -1
    Would be the same thing..., unless there is a better way or I just need to ignore the error since we only need the 8 LSB anyway.
    Richard
    Sep 2005
    Campbell, CA
    Are you doing SNMP by any chance?
    Charles Linquist
    No, Modbus ASCII LRC Calculation
    Assume LRC = 10.
    LRC = 256 - LRC. Which works out to LRC = 246, but returns a warning message.
    Now try this approach with LRC still = 10;
    LRC = $FF - LRC ' LRC = 255 - 10. Now LRC = 245
    LRC = LRC - 1. Now we have 245 - 1 which = 244. Oops! Not what we expected, although it
    looked darn good at 1st glance.
    Now try this, and see if you can figure out why it works & doesn't return the warning
    message;
    LRC = !256-LRC ' LRC = NOT 256 - LRC
    Here's a short test to verify it;
    LRC VAR BYTE
    X VAR BYTE
        FOR X = 0 TO 255
        LRC = X ' We'll work with LRC = 0 to 255 to prove it works
        HSEROUT ["256-",DEC X,"="]
        LRC = !256-LRC
        HSEROUT [DEC LRC,13,10]
        NEXT X
    Here:
        GOTO Here ' done
    Food for thought ehh....;o}
    A more efficient approach would be to just promote LRC to a word variable,
    and use the lower byte for your result, but this is pretty cool.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    .....Now try this, and see if you can figure out why it works & doesn't return the warning message;
    That's pretty slick...
    I almost missed it and was about to reply back that you were wrong in this instance. Good thing I didn't. My foot goes in my mouth enough as it is...
    It certainly wouldn't be the 1st time I was wrong, but it does work..;o}
    -Bruce
    tech at rentron.com
  1. 16F914 and MPASM
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 7th February 2009, 04:21
  2. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 02:29
  3. MPASM 18F4550 getting started
    Last Post: - 5th September 2007, 00:59
  4. 18F8722 and MPASM confusion!
    By Jackson in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2006, 02:24
  5. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
