ME Labs getting Lazy?
Results 1 to 40 of 44
    No, I have to agree with you in part, but I can see where MeLabs is comming from...
    1. If you are an Amatuer/Hobbyist, the default (18F defines for example) that you 'unpack out-of-the-box' allow the majority of the uninitiated to get the product to work in some form or other.
    2. Once you spill beyond basics into more custom designs, one hopes you have gained a sufficient knowledge now to be able to go beyond the basics and edit up your INCs and things. *sigh* I know, it's not perfect. Even as a Pro (no, I don't stand on street corners!), it trips me up sometimes. There's nothing more irritating to throw some code together, chose a new PIC that you haven't used before, and get a face full of compiler errors reminding you that you haven't edited that INC file.
    Ideally, what MeLabs could do, is have a compler switch eg /i (for /ignore or /idiot) which would cause the compiler not to use the default settings in the INC file and take it all from your program instead. It's not that difficult to parse a command line and impliment, and I always thought I'd get around and do it... but it's lack of time and I'm not that involved in day-to-day programming to bother anymore.
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Hello
    You can use Atmel controllers with programming language Bascom, that is very identical to PBP pro but more, more powerfull.
    Pedro
    Sep 2007
    I feel that MELabs is doing a great job. I have called for support on the trial version and received it without hesitation. I also had my disk munched just after receiving it in the mail and they replaced it for a minor shipping charge. I think the new power of 2.50 is great and I think they are advancing the product at a reasonable rate. Upgrades are sold at a very reasonable price. Have you ever upgraded a MS product for around 10% the cost of the original software? I am a beginner and have received a ton of help from MELabs, the manual, searching this forum and when all else failed posting for help. I think people need to appreciate how good we have it. I would love it if version 2.60 had integrated DMXIN and DMXOUT routines but like Melanie said that would be way too specialized so I will either learn how to do it myself or pay someone to do it for me.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    Quote Originally Posted by Pedro Pinto View Post
    Hello
    Pedro
    I have to disagree a bit (I said a bit, I didn't entirely!). Atmel/8051 based MCU's have been around longer than PICs, they have a larger following, but as far as more powerful? The power is behind the keyboard...not in the chip.
    Quote Originally Posted by krohtech View Post
    As far as the 'extended' command set goes, if you have written yourself a nice set of PBP extensions (see the Forum topic of the same name), you can easily INCLUDE them for easy access just as a normal PBP command, well, almost as easily. For instance, the PRINTSTR functions that I use for the graphic LCDs, I include 'nokiaknockoff.bas' into my main program. The 'nokiaknockoff.bas' file has the PBP code along with assembly extensions and I access those commands with a simple:
    @ printstr 5,6,"this is my function"
    inline with my normal PBP code...simple as that.
    If you are able to get decent DMXIN/DMXOUT subroutines running, you can easily do the same, whether it be thru a GOSUB or a MACRO.
    Of course it's not quite a good as the real thing, but it's a great stepping stone to learning the inner-workings of PBP and compilers in general.
    Pedro Pinto Guest
    SKIMASK says:
    I have in my previews posting that Bascom are more powerfull and not the chip
    Pedro
    Pedro
    See and read Post #3...
    The power of ANY compiler/assembler/anything is in the keyboard/lever/anything operator...not the chip/engine/whatever.
    Bascom may have more functions built into it when it comes from the factory, but is it really 'more powerful'?
    It just means that somebody took the time to code more functionality into it (i.e. operated the keyboard better).
    Again...Post #3...
    You can have 2 out of 3...Fast, Cheap, Good
    Fast and Cheap, won't be Good...
    Cheap and Good, won't be Fast...
    Fast and Good, won't be Cheap...
    Sep 2006
    Indiana, USA
    Default I disagree with you all on many levels..
    If you don't innovate your product and you stand behind the whole "here it is, if it isnt good enough, go p*ss up a rope" mentallity, you will get smoked in the end by someone that is willing to innovate. period. the microsofts of the world never innovated, they only bought what someone else had already done and marketed it under the MS brand and now are in the position to charge an outragous price because they now have enough money to sue or buy out their enemies. it isn't because they offer a better product, far from it, they just don't give you a choice. but with micro's you DO have a choice, and I say if MElabs doesn't offer what you like, by all means find something better. and its great that some of us have found a market that they can use PBP in their business, and thats what they do all day, program in PBP, so they understand it top to bottom (and they probably don't know it all either), but some of us have other things to do, this is simply a hobby, and all we ask for is some help now and then from someone who's been there, done that.
    Mr. Gates would have never in a million years been able to code windows, he was just smart enough to convice people to do it for him.
    PBP like the above poster said was only meant to offer an alternative to basic stamps, which is typically more of a hobby item, so it would stand to reason more people are using PBP as a hobby.. So a message board that offers people help on projects is a great idea, but acting like someone is stupid because they ask for help is kinda lame (the first project in the PBP manual is how to flash a single LED, afterall).. And someone who only programs in assembly could say programming in basic is for people that need their hand held, and just about everyone who loves C do say that! So again, i'd go talk to MElabs, and if they don't see it your way, go fish in another sea!
  1. 16f877 and ps/2 keyboard error???
    By boraciner in forum mel PIC BASIC Pro
    Last Post: - 5th July 2009, 08:14
  2. ME Labs Loader program - file for 16f88
    By Ken Howell in forum Off Topic
    Last Post: - 24th January 2007, 03:12
  3. Help with me labs Bootloader
    By teknoman2420 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2006, 09:37
  4. microEnginnering Labs Programmers - Reduced to Clear
    By David Barker in forum Adverts
    Last Post: - 29th June 2006, 13:31
