Nokia COLOR LCD PicBasicPro 2.50a example code
Results 1 to 40 of 50
    Sao Paulo - Brazil
    Hello Dave,
    sorry for my alte response (I had a small car accident yesterday).
    Thank you very much for your response. If you want, you can send it to [email protected]
    I think gmail can handle big atached files !
    Don't worry about the Code comments
    First, I will try everything without USB connection. After that I will try to implement everything together !
    Thank you again !
    regards.
    Sérgio
    Mar 2008
    Gerogetown, Texas
    Sérgio
    Did you get the files I sent you?
    Sao Paulo - Brazil
    Hi Dave,
    Thak you for your reply.
    Yes, I receive your e-mail on my gmail account, but, the files were received by gmail as plain text... strange... is the zip files bigger than 2 Mbytes each ?
    regards.
    Sérgio
    Mar 2008
    Gerogetown, Texas
    Sérgio
    I took out some of the supporting files, here is the VB6 code and the PBP files. Again, I am using the microchip USB Boot-loader, EasyHid so you will need to load the drivers for these programs. I also use a BMP to HEX editor to produce the color Images on the display. I send them via USB 64 bytes at a time so the picture loads fairly fast.
    Good luck
    Out of curiosity, which BMP to HEX software are you using?
    Sounds like the beginnings of one of those mini- LCD picture viewer things...
    Sao Paulo - Brazil
    Hi Dave,
    thank you very much for these files !
    Well, last weekend I changed your first code removing the USB stuf and the picture download.
    It worked very well !
    I bought 1 LCD and 2 breakout boards from SparkFun. One of the boards are not working (the LCD keep the backlight lit and nothing happens). Checked the connector and discovered that 2 connector´s legs are short circuited.
    So, the LCD was installed in the another board and everything worked fine.
    My board is running with a 20 Mhz crystal, but I think it is a bit slow. So, I will change it to full speed and check if it gets better.
    Well, I will check your new files and see what I will need to change here !
    Tahnk you Again !
    PS. Did some one here successful on buying some Lib from ComSys1 ? I have been trying to contact them to buy the KS0108 Graphic lib but they never answer the e-mails!
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. PicBasicPro Code help!
    By michel in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 16:43
