Help With stack (STKPTR)
Results 1 to 4 of 4
    Feb 2008
    well the task i have to complete requires me to use a stack..........we are getting to grips with how to use the pic and to use interrupts....so when a interrupt happens i wanna save the contexts of the WREG, STATUS and the BSR into each section of the stack. this is to be done with three different routines the ISR will run.......... i have done this by using MOVFF into registers but now i wanna use a stack
    Very strange assignment.
    Definitely not the way to do things.
    I can say, the only part of the stack that's available to read/write is the TOS (Top Of Stack).
    You can NOT split it in thirds and have 3 TOS's.
    To do what you are suggesting, you would need to create your own stacks in software, and POP the entries off the hardware stack, then put them in your own stacks. Then in reverse order, to pop them off your stack.
    But I really see no benefit, other than learning. And it's NOT beginners stuff.
  1. PBP method to POP or PUSH to 18F2525 stack?
    Last Post: - 26th September 2009, 21:09
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Stkptr
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 12th March 2007, 21:50
  4. Stack Under flow
    By Wayne in forum mel PIC BASIC Pro
    Last Post: - 14th September 2005, 14:22
  5. 48 level Software Stack
    Last Post: - 30th November 2003, 02:07
