Keep in mind that any changes on PORTB.6 or 7 will also trigger an interrupt. It's best to Not Use 6 and 7 for anything else.
Code:Old_Bits VAR BYTE New_Bits VAR BYTE INCLUDE "DT_INTS-18.bas" ' Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RBC_INT, _RBC_handler, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM Old_Bits = PORTB @ INT_ENABLE RBC_INT ;RB Port Change Interrupt Main: Pause 1000 GOTO Main '---[RBC - interrupt handler]--------------------------------------------------- RBC_handler: New_Bits = PORTB IF (New_Bits.4 <> Old_Bits.4) THEN ; -- PORTB.4 has changed -- ENDIF IF (New_Bits.5 <> Old_Bits.5) THEN ; -- PORTB.5 has changed -- ENDIF Old_Bits = New_Bits @ INT_RETURN
