Not the first time, because you'll be writing to areas that were erased when it was programmed.
If you ever want to write over then same locations again, then you have to erase it first.
Section 3.6 in the 819's datasheet.now for the one piece of information that will allow me to fish for myself: where are the pieces of information about block size, the number of bytes/words to write before they are actually written, and if a block first needs to be erased located in a typical datasheet?
Take a look at this ...i'm currently trying to get USART interrupts working using your instant interrupts system. just need to figure out how to grab the byte from the buffer so i can store it.
http://www.picbasic.co.uk/forum/show...?p=28336#28336
