PWM setting PIC16F887
Results 1 to 7 of 7
    Quote Originally Posted by Gevo View Post
    Hello,
    I work on a application and need two hardware PWM outputs. One PWM (CCP1) to
    control a DC motordriver LMD18200 (10 Khz) and one PWM (CCP2) for IR comm (38KHz)
    The motor is still running, but runs on 1 KHZ. (I need 10KHz or maybe the same 38KHz as the IR Comm.)
    Might help you out...
    http://www.mister-e.org/pages/utilitiespag.html
    You can have different duty-cycles, but the frequency will be the same on both CCP1 & CCP2 since they both use the PR2 register of TIMER2 for the PWM period.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hey...good point...Duh on my part...
    Set up a 555 timer for a 50% 38Khz square and turn it on/off with a PIC pin, or use a 2nd PIC set up for the same thing as the 555. An 8-pin PIC makes a helluva useful 555 timer....with a load of options...
    -Bruce
    tech at rentron.com
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  4. PWM 'channels ...what's that all about then!
    By HankMcSpank in forum General
    Last Post: - 23rd April 2009, 17:49
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
