PWM setting PIC16F887
Results 1 to 7 of 7
    Jul 2005
    The Netherlands
    Default PWM setting PIC16F887
    Hello,
    I work on a application and need two hardware PWM outputs. One PWM (CCP1) to
    control a DC motordriver LMD18200 (10 Khz) and one PWM (CCP2) for IR comm (38KHz)
    The motor is still running, but runs on 1 KHZ. (I need 10KHz or maybe the same 38KHz as the IR Comm.)
    Questions:
    - Runs CCP1 and CCP2 with the same Timer2 Prescale settings ?
    - So, can I set different frequences on the two PWM channels ?
    Thanks for replays,
    Regards, Gevo
    The setting in my program:
    ' PIC16F887
    DEFINE OSC 4 ' Inform PBP PIC Speed
    OSCCON = %01100111 ' Internal Clock set to 4MHZ
    INTCON.7 = 0 ' Disable interrupts.
    CM1CON0 = 0 ' Comparators off
    CM2CON0 = 0 ' Comparators off
    ' Motor PWM settings
    TRISC.2 = 0 ' Set PORTC.2 (CCP1) to output
    CCP1CON = %00001100 ' Set CCP1 to PWM, ACTIVE HIGH
    T2CON = %00000101 ' Timer2 ON, Prescale 1:4
    PR2 = 249 ' Set PWM Periode to 1 KHz
    ' IR COMM PWM settings
    TRISC.1 = 0 ' Set PORTC.1 (CCP2) to output
    CCP2CON = %00001100 ' Set CCP2 to PWM, active high
    T2CON = %00000100 ' Timer2 ON, Prescale 1:1
    CCPR1L = 13 ' Set PWM Duty-Cycle to 50%
    PR2 = 25 ' Set PWM Periode to 38 KHz
    Quote Originally Posted by Gevo View Post
    Hello,
    Might help you out...
    http://www.mister-e.org/pages/utilitiespag.html
    You can have different duty-cycles, but the frequency will be the same on both CCP1 & CCP2 since they both use the PR2 register of TIMER2 for the PWM period.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hey...good point...Duh on my part...
    Set up a 555 timer for a 50% 38Khz square and turn it on/off with a PIC pin, or use a 2nd PIC set up for the same thing as the 555. An 8-pin PIC makes a helluva useful 555 timer....with a load of options...
    -Bruce
    tech at rentron.com
    SWITZERLAND (french speaking)
    Default contact
    Hi Gevo,
    What is your email adress? I can't reply to your pm.
    Roger
    Jul 2005
    The Netherlands
    Default Email address Gevo
    Hi Roger,
    Thnx for your replay.
    My direct Email adress: [email protected]
    Beste Regards,
    Gerben Voort
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  4. PWM 'channels ...what's that all about then!
    By HankMcSpank in forum General
    Last Post: - 23rd April 2009, 16:49
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
