Define for extern oscillator
Results 1 to 4 of 4
    Jan 2008
    Selm, Germany
    Wink Define for extern oscillator
    Hello Ladies & Sirs,
    because of my difficulties as a PIC newbe (since a single year) i would like to get a simple OSC setting in PBP for external canned oscillators. Something that works with MPASM and corrects evrything by itself. Or a separate file that works itself without searching for the "clerk-fuse-of the master-fuse-inthe under-under-under-directory...."
    is that possible?
    With regards
    M.David
    Quote Originally Posted by Mugelpower View Post
    is that possible?
    With regards
    M.David
    http://www.ni.com/academic/mindstorms/works.htm
    is that possible?
    With regards
    M.David
    Read this thread:
    Then read this thread:
    Then read them both again, play with them, play with the settings, play with things, (remember to backup/rename everything you change so you can change it back if you mess it up).
    Once you get this down, the rest should be cake.
    Like I told you, there's a steep initial learning curve, after that's gone, it's all downhill (or maybe uphill?) from there.
    That's the price you pay for having a fair amount of RISC processing power at your fingertips.
    If we all didn't need this kind of processing power, we'd all still be using DOS 3.11 and the guys at Microsoft wouldn't have a job.
    Jan 2008
    Selm, Germany
    Smile wish list
    hey Skimask,
    yes i read it and now my osc defines are working, at last for my 16F628A.
    But: do I have to dig that deep into the defines? Ok. maybe the software has to be more expensive , who knows.
  1. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  2. PIC16F877A analog problem
    By DeViLa_Q8 in forum mel PIC BASIC
    Last Post: - 30th July 2009, 21:19
  3. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
  4. PIC HSERIN problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 20th July 2008, 12:08
  5. Replies: 8
    Last Post: - 17th September 2006, 18:46
