Software ADC Comparator?
Results 1 to 14 of 14
    Sep 2006
    Indiana, USA
    Default still not it..
    I tired your code, Jerson, and it didn't seem to work right, say the ADC had 2.5 volts applied, and then i turned the voltage up to 3 volts, the output would turn on and off, over and over, rather than toggle once, to show a change happened, and then stop. i changed the threshold value to account for any instabilty in my input voltage, and still no dice. and like a i said before, i need the circuit to "readjust automatically" so that it only cares that there is a positive increase in voltage by a certain value and reacts once and then resets, it shouldn't care what the original ADC value was, only that the value increased. so it would have to "dynamically" adjust itself. you would figure that you would take a reading, and then some miliseconds later, take another reading, subtract the first value from the second and that number would show a difference (if there is any), which would mean a positive change. if that value was over that of the threshold, then react. you would have to clamp that value to a number between 0 and 1023, so there wouldn't be a negative value and a roll over (or under, in this case) which i think is what Jerson's code showed, and i already tried the same thing, in a slightly different way, and neither work... but i could be, and probably am missing something! i really don't understand absolute values (only their vodka!) and how it applies here, all your saying is that the number can only have a certain maximum value right? so couldn't i use MAX?
    Like skimask said, you have the code in you explanation of the project.
    Jerson gave an "untested" example to get you started.
    Think about this:
    Two VAR : read ADC first : write that value to VAR1 : start LOOP : read ADC :_
    write ADC value to VAR2 : IF VAR2 > VAR1 THEN ? : Now make VAR1 = VAR2_
    GOTO LOOP
    Sep 2006
    Indiana, USA
    Default This is what i have.
    This is what i got so far, and im not seeing why it doesn't work.
    please excuse the formatting and what not!
    @ DEVICE pic16F684, HS_OSC, WDT_OFF, PWRT_OFF, MCLR_ON, BOD_OFF, IESO_OFF, FCMEN_OFF
    DEFINE OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 11
    CMCON0 = %00000111
    VRCON = %00000000
    ANSEL = %00110100
    ADCON0.6 = 0
    ADCON0.7 = 0
    voltLevBf VAR WORD
    voltLevAf VAR WORD
    voltLevCk VAR WORD
    threshHold VAR WORD
    timOut VAR WORD
    prgSel VAR PORTC.2
    swtOut VAR PORTC.3
    CLEAR
    PAUSE 1000
    autoGainPrg:
    ADCIN 2, voltLevBf
    PAUSEUS 12
    ADCIN 4, threshHold
    PAUSEUS 12
    ADCIN 2, voltLevAf
    PAUSEUS 12
    voltLevCk = voltLevAf - voltLevBf
    IF voltLevCk > threshHold THEN
    HIGH swtOut
    PAUSE 60
    LOW swtOut
    ADCIN 5, timOut
    PAUSEUS 12
    PAUSE timOut
    GOTO autoGainPrg:
    the ADC acts as if there are two seperate voltage values present at the pin even if the voltage is the same and doesnt change. like on the first reading it should read 3 volts, and the second reading should be 3 volts or close enough! it shouldn't flash the LED sitting on the output, but its does, over and over like a blinky circuit, like the two readings are never close to equal, no matter what threshold is set at! so that would make me think that the difference between the two readings is somehow always larger than threshold.. what i'd like to know is, what did Jerson mean by "if Error < 0 then Error = -Error ' make absolute error" ?
    IF Error < 0 THEN
    Error = Error - Error
    ??? if so, i tried that version of it, and it didn't work either..
    Bombay, India
    Ryan
    You seem to be reading 3 diff adc ports. First of all, you have to tell us what is each one for any of the code I gave to make sense.
    The code I gave wants only 1 adc port to sense the light intensity. So, the other 2 are redundant. And the code I gave should do exactly what you asked for.
    Check your code. You seem to have got it diff from what I have given you.
    in Pseudo code what I have sent you does this
    if CurrentADC != PreviousADC
    Output = high
    Wait 1 second
    Output = Low
    PreviousADC = CurrentADC
    Jerson
    Sep 2006
    Indiana, USA
    Default ok
    here is where i am now, and it still doesn't work, no matter.. also, if I were to set my current reading and previous readings equal, the next loop through would set them to what ever the ADC says at sample time anyway.. so it would be pointless wouldn't it?
    PreviousADC = CurrentADC ?
    DEFINE OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    CMCON0 = %00000111
    VRCON = %00000000
    ANSEL = %00110100
    ADCON0.6 = 0
    ADCON0.7 = 0
    voltLevBf VAR WORD ' variable for first reading or "previous"
    voltLevAf VAR WORD ' variable for second reading "current"
    voltLevCk VAR WORD ' variable for holding the difference
    threshHold VAR WORD ' variable for the threshold
    timOut VAR WORD ' variable for holding the timeout
    prgSel VAR PORTC.2 ' not in use yet
    swtOut VAR PORTC.3 ' output to LED
    CLEAR
    PAUSE 1000
    autoGainPrg:
    ADCIN 2, voltLevBf ' sample voltage on ADC 2
    PAUSEUS 12
    ADCIN 4, threshHold ' get threshold from pot set up as volt. divider on ADC 4
    PAUSEUS 12
    ADCIN 2, voltLevAf ' sample voltage on ADC 2 again, to check for difference
    PAUSEUS 12
    IF lghtlevAf > lghtlevbf THEN ' IF the second reading is higher than the first,
    voltLevCk = voltLevAf - voltLevBf ' subtract the first reading from the second to get the Dif.
    IF voltLevCk > threshHold THEN ' IF there is a difference, and it is greater then threshold
    HIGH swtOut ' set the LED high
    PAUSE 60 ' pause for 60 mS
    LOW swtOut
    ADCIN 5, timOut ' check volt. div pot on ADC 5, use number as time out - 0 to 1023
    PAUSEUS 12
    PAUSE timOut ' Pause for the time out setting, determined by ADC 5
    GOTO autoGainPrg:
    Sep 2006
    Indiana, USA
    Default Hope this doesn't make anyones head explode!
    just to make sure the problem i need to solve is clear, i will explain what i want yet again.
    I will not be monitoring a sine wave, the signal will not vary that often actually and will never go negative in relation to ground. but for the sake of an example, I will use sinewave.
    Say that there is a sine wave, the frequency of which does not matter, that is 2 Vp-p.
    This Sine wave is "floating" with its zero point at 2 volts above ground, making the lowest peak 1 volt, and the highest peak 3 volts. then we'll say my threshold is set at 1.5V.
    When the sine wave reaches 1.5V above the 1 volt line (not ground!), it triggers a response from my circuit, or flashes the LED once, and then waits.
    Where the sine wave is "floating" (again, floating, not peaking) doesn't matter, it will be anywhere between 0 and 5 volts and is out of my control, it is an independent circuit.
    The PIC circuit only needs to trigger when there is a positive going change in voltage that exceeds a threshold that i will need to have control of. so therefore, the threshold has to follow the 1 volt ( or 2V or whatever!) line automatically, while i can vary the threshold level, it will always be in reference to the 1 volt line! not ground. please see my example.bmp
    (and yes i know that if my threshold is 1.5 volts, and the signal zero reference exceeds 3.5, the threshold will be out of range, and that is fine because 1.5V is only an example.)
    Bombay, India
    Ryan
    Now, I understand what you're trying to do. However, reading the adc like this hardly gives you anything worthwhile.
    PAUSEUS 12
    PAUSEUS 12
    PAUSEUS 12
    Why? The difference between the 2 samples on ADC 2 is just around 25uS. Is this what you really want??
    On reading closely, I think you need to do this
    'Find the minimum value
    MinAdc var word         'I'm assuming the ADC to be 10bit or more
    CurrAdc var word
    Threshold var word
    DelayVal  var word
    while 1                                     ' loop forever
        ADCIN 2, CurrAdc                    ' current ADC reading
        ADCIN 4, Threshold                 ' threshold setting
        ADCIN 5, DelayVal                   ' delay setting
        if CurrAdc > MinAdc + Threshold then
               High Output
               pause DelayVal
               Low Output
               if CurrAdc <> MinAdc then  ' check if the current ADC value < Min ADC
                 MinAdc = CurrAdc          ' and correct the MinADC value
    wend
    Does this do what you want?
    Jerson
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 02:18
  2. Comparator circuit thoughts....
    Last Post: - 24th October 2009, 06:04
  3. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 10:04
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 15:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 01:55
