Software ADC Comparator?
Results 1 to 14 of 14
    Sep 2006
    Indiana, USA
    Default Software ADC Comparator?
    I don't know if comparator is the proper term, but I need some direction here!
    I need to measure a voltage on a ADC input and then set an output high when the input voltage goes higher than the original reading, no matter what the original reading was (not exceeding 5 volts or full scale of the ADC of course). sort of like an autogain of some type. I'd like to be able to adjust the gain (or level of difference) of the readings with another ADC input and pot. so:
    if the original reading on AN0 was 2.33 volts
    and then right after that the next reading on AN0 exceeds 2.33 volts by 1 volt (3.33)
    High myOutput once, for one second.
    so then if the next reading is 3.33 it does nothing, because there was no positive change
    but, if the next reading is 4.33 then the output goes high again because there was a positive change.
    and so on
    the difference being 1 volt, which i would also like to have control of with another ADC..
    the voltage on my ADC input is going to vary between 1 - 4 (thereabouts!) slowly, with only sudden bursts of a higher voltage for a short pulse (a few mS?) but i think my PIC (F684, 20 MHz) will be able to capture it.
    I already know how to set up ADCs, and do my Defines and all of that, I just need some workable code here. Thanks in advance for any help!
    IF ADCVAR <= to x THEN
    DO SOMETHING
    IF ADCVAR >= to x THEN
    DO SOMETING ELSE
    EDNIF
    Is that what you are looking for ?
    Might help to know the end application...
    Sep 2006
    Indiana, USA
    Default No..
    the first suggestion by mackrackit doesn't take into account the level of "difference"
    i.e. setting the output high based on the amount of change of a varible number, not just by the fact that it changed for one.
    and its classified skimask! but, heres an example:
    say my input is a light dependent resistor, or solar cell, whatever, and its sitting in a dark room, doing nothing, no output. then someone turns on a dim light, the pic would detect the change in light level in the span of one loop, and toggle an output on and off one time because it saw a positve change in voltage on the ADC.
    Then it readjusts for the new light level in the room and sits there, doing nothing, but someone makes the light a bit brighter, and again the output toggles because there is a positve change in light. so therefore, it only toggles the output because there is a positve change in light, it would ignore someone turning the light off, or dimming it. I also need control of how much of a positive change it responds to, like the amount that the voltage level is increased, so if its a very slight change, nothing happens, but if there is a large change, it will respond..
    this is really messing with my poor ol' brain! but i seem to end up asking more questions on here than answering anyway!
    Also, when i say "readjusts" i mean the circuit automatically readjusts its self, like autogain, or something!
    thanks again for your help!
    Quote Originally Posted by Ryan7777 View Post
    I've seen classified (or have I?)...this isn't classified (or is it?)...
    say my input is a light dependent resistor, or solar cell, whatever, and its sitting in a dark room, doing nothing, no output. then someone turns on a dim light, the pic would detect the change in light level in the span of one loop, and toggle an output on and off one time because it saw a positve change in voltage on the ADC. Then it readjusts for the new light level in the room and sits there, doing nothing, but someone makes the light a bit brighter, and again the output toggles because there is a positve change in light. so therefore, it only toggles the output because there is a positve change in light, it would ignore someone turning the light off, or dimming it. I also need control of how much of a positive change it responds to, like the amount that the voltage level is increased, so if its a very slight change, nothing happens, but if there is a large change, it will respond..
    If you read thru what you wrote carefully enough...you've just wrote the program that you want....no, really. I was writing it as I was reading it.
    Now my question is, the input can only go so high. Once it gets up to a maximum value, what's going to bring it back down to a nominal nothing?
    Bombay, India
    Ryan
    What you're looking for is a derivative function. What you can do is something like this
    LastADC  var   word    ' previous error
    CurrADC  var   word    ' current error
    Threshold con  1        ' can be more if you want
    loop:
      gosub ReadADC
      Error = CurrADC-LastADC
      if Error < 0 then Error = -Error ' make absolute error
      if Error > Threshold then
        High Output
        pause 1000    ' wait 1 second
        Low Output
      LastAdc = CurrAdc
      goto loop
    This will more or less achieve what you want to. However, this is pure untested code. Use at your own risk.
    Jerson
    Sep 2006
    Indiana, USA
    Default still not it..
    I tired your code, Jerson, and it didn't seem to work right, say the ADC had 2.5 volts applied, and then i turned the voltage up to 3 volts, the output would turn on and off, over and over, rather than toggle once, to show a change happened, and then stop. i changed the threshold value to account for any instabilty in my input voltage, and still no dice. and like a i said before, i need the circuit to "readjust automatically" so that it only cares that there is a positive increase in voltage by a certain value and reacts once and then resets, it shouldn't care what the original ADC value was, only that the value increased. so it would have to "dynamically" adjust itself. you would figure that you would take a reading, and then some miliseconds later, take another reading, subtract the first value from the second and that number would show a difference (if there is any), which would mean a positive change. if that value was over that of the threshold, then react. you would have to clamp that value to a number between 0 and 1023, so there wouldn't be a negative value and a roll over (or under, in this case) which i think is what Jerson's code showed, and i already tried the same thing, in a slightly different way, and neither work... but i could be, and probably am missing something! i really don't understand absolute values (only their vodka!) and how it applies here, all your saying is that the number can only have a certain maximum value right? so couldn't i use MAX?
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Comparator circuit thoughts....
    Last Post: - 24th October 2009, 07:04
  3. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
