ICSP wireless?
Results 1 to 5 of 5
Thread: ICSP wireless?
    Jul 2007
    Default ICSP wireless?
    Can you make ICSP wireless?
    If, how?
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by xobx View Post
    If, how?
    PIC with a Bootloader re-programmed over a wireless serial link...
    PIC with a bootloader re-programmed over a 802.11b/g/n link...
    PIC with a bootloader re-programmed over a (it's fairly new and I'm not sure of it's implementation or even if it's possible) Wireless USB link...
    In any case, has to be a bi-directional link...
    You can have 2 out of 3 here, Cheap, Easy, Good
    Cheap and Easy, won't be good...
    Easy and Good, won't be cheap...
    Good and Cheap, won't be easy...
    Wireless boot-loading is easy. It's not cheap though. Wireless in-circuit programming would be a nice challenge.
    You need Vpp, clock and data on the receiving end, so you'll pretty much need a bi-directional link from PC to a
    remote device programmer with a few custom goodies in the mix.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    skimask's Avatar
    skimask Guest
    There ya go, Easy and Good, but not Cheap.
    If the receiving circuit already had it's own power, should be a piece of cake to add a small boost converter for Vpp unless of course the PIC had been CONFIG'd for LVP in the first place.
    I didn't see any bi-directional modules on your site, but I'd guess a 'speak only when spoken to' type setup using the modules on your site might not be out of the question.
    A wireless module that would, in essence, sit on the ICSP pins like a PICKIT2 does?
    This sounds like a bit of fun...except that a person is reinventing the wheel...with all of the various programming spec's out there for the PICs.
    Hi Ski,
    You can use a couple pair of transmitter/receiver modules to slap together a bi-directional link. If you know what you're doing..;o}
    We'll have the new Linx Technologies LT series transceivers here shortly, so I'll give the wireless loader thing another go when I get time.
    My 1st shot was a pair of rather expensive transceivers, but I think I can make it happen with the much less expensive stuff. Just have to find the time. A modified version of the Tiny loader should be nice since it's free.
    I've done a wireless loader with our Fyre-Fly IR transceivers too. That was fun.
    -Bruce
    tech at rentron.com
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 18:31
  2. what IS an ICSP connector?
    By mslaney in forum Schematics
    Last Post: - 5th March 2008, 08:05
  3. Replies: 1
    Last Post: - 11th December 2007, 00:57
  4. ICSP Programming from a PDA
    By Ralph in forum Off Topic
    Last Post: - 11th November 2007, 23:22
  5. Wireless communication gear.
    By toalan in forum Off Topic
    Last Post: - 17th March 2005, 17:33
