Roman Black Sound (btc)
Results 1 to 40 of 58
    Cambridge UK
    Hi Ioannis,
    Have you used the ISD chips much? I have managed to write some code for the the isd4003 with SPI control about 18 months ago, but since then that type has been discontinued in the UK. I have got some of the 1700 series chipcorders and have been playing with them in push button mode. The problem I have with them is removing the pop and hiss that that is in the back ground when in play back, if I could remove or attenuate it they would be fine for my application. I found this last week when searching for ideas, it uses the audio out and parallel port for control.
    www.fragtag.com.au/ISD_recorder.htm
    Which makes them more appealing, like I said if I could remove the noise i'd be using them.
    I have the circuit built as per the data sheet, with an lm386 audio amp connected to the speaker output. If you have any ideas they would be great.
    regards Nick
    It was long time ago when I read the datasheets of the ISD products trying to decide which one to use. Finally the project did not mke it to production and I never used these chips, although I have some to experiment. I may do it sometime.
    Why not process the file on a sound editor program on the PC, and then use the line out of the PC to record the clean sound to the ISD?
    Aug 2003
    I wish I'd noticed this before doing my talking clock.
    Or maybe not now that it's done in asm.
    BTW EEPROM is good for storing sound.
    I think a PicBasic version would be nice though, for projects where everything can
    fit in one chip.
    For a version in basic see PIC iPod wav player
    Norm
    Apr 2006
    Michigan
    Here is an update to my project. I brought the roman black board and it does work. I tried many band pass filters and the quality is terrible. The only way to even get decent quality was to have a speaker in an enclosure. That did more to filter out the noise, but it still wasn't great. I settled on a windbond device. I wouldn't waste time or money with this method.
    Look also at the 4D SOMO Module here: http://www.4dsystems.com.au/prod.php?id=73 .
    Feb 2008
    schu4647-
    Hi, the BTc system was never designed for *high quality* sound! It's strangths are in other ways, mainly that the PIC microcontroller can also be used to do other tasks, all in one self contained module, and that is quite memory efficient.
    Which speaker were you using that sounded terrible? For better sound quality I suggest a speaker with a larger diameter, ie 4" or 6". The tiny speakers that are supplied (free of charge!) with the product are not meant for good sound (they are "scratchy") and are only for small self contained applications like little robots, talking remote controls etc.
    The BTc module sold is optimised for general purpose control applications and has source code, so you can use that one module to operate servos and play speech clips, or control a small device with some talking feedback. Or be used as a complete talking remote control all with the one PIC in the one module with its own 5v regulator and tiny low-sound quality amp already built in.
    If all you want is something to play a sound, or specifically need high quality sound then there are plenty of options including the Winbond chips and $10 MP3 players from the supermarket.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. new to PIC programming could really do with some help
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 15:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
  5. Re: quick fix for sound command?
    Last Post: - 9th July 2004, 02:44
