PWM configuration
Results 1 to 2 of 2
    Jul 2004
    CA
    Default PWM configuration
    hello everyone,
    I am using the 16F77 with a 20Mhz crystal, I have tried the software PWM multiple times and and a bit dissatisfied because I cannot do anything else while I am in the PWM loop. What I want to do is have the PWM going in the background, but I do not want to use the HPWM option I have with PBP. but instead want to just set the appropriate registers myself. I was wondering if someone is willing to help me.
    here is what I have so far. I have read the CHIP's manual and here is what it recommend I do.
    1)Set the PWM period by wrigint to the PR2 register.
    2)Set the PWM duty cycle b writing to the CCPR1L register and CCP1CON <5:4>
    3)Make the CCP1 pin an output by clearing the TRISC<2> bit
    4) Set the TMR2 prescalar value and enable Timer2 by writing to T2CON
    5)Configure the CCP1 module for PWM operation.
    Since I wanted to generate a signal around roughly 1khz and have the duty run from 0 to 100% .
    I have the following at the top of my code
    PR2 = %11111111 'equivalent to 0xFF for 1.22khz at 20Mhz
    CCP1CON = %00110000
    TRISC = %00000000
    T2CON = %00000111 'starts timer and set prescalar to 16
    I am not sure if this is all that is required to start the PWM function for this PIC microcontroller. Again I do not want to use the HPWM that is readily available to me by PBP.
    Please, Any help with this would be greatly appreciated. Thank you.
    srigopal
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
