16F88 7 data bits
Results 1 to 13 of 13
    Default 16F88 7 data bits
    I have to set up for 9600, 7,N,1 and I do see the defines in PBP :
    Define SER_BITS 7 But I need to be able to do it during runtime.
    I don't understand how to do it using the 16F88 Datasheet.
    I know how to do the Baud Rate during runtime as I've done that many times.
    Richard
    Quote Originally Posted by rwskinner View Post
    Richard
    Are you saying that you have to switch back and forth between 8N1 and 7N1?
    Short of writing your own serial routines, I don't see it happening with PBP.
    A thought (if in fact it's not possible to switch between 7N1 and 8N1), how about putting a 'hijacking' PIC in between the receiving PIC and the sending device to receive 7N1 in software and send out 8N1 in hardware....a sort of buffering translator...I can see a 16F628A doing that rather easily.
    Feb 2003
    Salt Lake City, Utah USA
    >>Define SER_BITS 7
    I think you mean DEFINE SER2_BITS 7 and this is for software Serial Out (not Hardware) so the data sheet will not help in this case. The hardware UART (on all PICs?) does not support 7N1.
    Something to try: two adjacent pins connected together ... set one for output using SEROUT 8N1. Set the adjacent pin for output using SEROUT2 7N1. Make the pin not in use an input - switch back and forth as needed. You also could use the USART for the 8N1 rather than SEROUT. You might need weak pullups (or pulldowns if inverted mode) to ensure the serial line is not corrupted when you switch between pins.
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Quote Originally Posted by paul borgmeier View Post
    >>Define SER_BITS 7
    Good Luck
    I thought the DEFINE for SERIN/SEROUT stuck constant for the whole program...like you can't re-DEFINE it.
    Feb 2003
    Smile
    They do - that is why I suggested using SEROUT for one and SEROUT2 for the other. They are not related by the defines
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    AHA! Missed that!
    Yes, two protocols jumper selectable. When I power up, I check the jumper then use the proper protocol. Modbus ASCII 9600,N,7,1 or Modbus RTU 9600,N,8,1. The device needs to be changed on the fly depending on the equipment it's being hooked to.
    I know my CCS Compiler allows these settings but the project is an existing PBP project. I hate to have to convert it all.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
